RV.Net Open Roads Forum: Fifth-Wheels: Has anyone ever had their milk
 > Has anyone ever had their milk
CPC
San Fernando Valley, USA
Posted: 08/20/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
go bad while on a trip? We went on a short (4) day trip and when we returned and had breakfast the next day I found (the hard way) that our milk had soured. I kept the frig. on a high setting (7 of 9). We do not keep the milk in the door of the frig because it is not as cold as in the middle of the frig. and in spite of all this it went bad. The outside temp. was in the mid 90s, but we had the air conditioner on most of the day so that shouldn't have been a problem. We've not had this happen before and we've had several 3 month trips (though most of which were in cooler weather). Could it just have been that the milk was marginal to begin with, or maybe our frig. is just not a cold as it should be. Every thing felt very cold including the milk.
local temperature
Our Pics.
Luke Porter
Not on the road :(
Posted: 08/20/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
I keep my frige on the colder side, 4 out of 5. Runs about 40 degrees. Seems like the soda and such isn't really very cold.
Run my home fridge close to 32. Soda is cold. Milk lasts a lot longer.
States I have spent the night in my current rig, bought three years ago.
Have RV'ed through 49 states and been in all 50, just short of my half-century.
Vulcaneer
Northern New England
Posted: 08/20/08 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
If the fridge was operating at the correct temp all the time, The milk was probably bad to start with.
But another scenario, if you put the milk in before you started the fridge, it takes a good 24 to 48 hours for your fridge to get down to temp. Especially on gas in ambient temps. I start my fridge 2 days before placing perishables into it. This avoids a spoilage problem.
If you think soured milk is bad, try warm beer. That is really gross.
* This post was edited 08/20/08 04:22pm by Vulcaneer *
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
5th4me
calif
Posted: 08/20/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a bad expiration date on the milk carton.
SwanInWA
The Evergreen State
Posted: 08/20/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I would be leaning towards a bad batch of milk like the others have said. It might not hurt to buy a $3 fridge thermometer and just regulate your temp a little closer. Also, there are people on the forum who talk about buying a small fridge fan to circulate the air. I don't have a fan but I'm sure some of the nice folks on here would be happy to give some info. Sour milk isn't a fun way to start the day!
Teri--the RV.net addict!
DEAR and WONDERFUL husband Eric
(& furry faced Angus!)
Western Washington
lovemountains
North Carolina
We find it helpful to use a thermometer with a wireless sensor in the TT refrigerator. We can check the temperature without opening the door. It can flucuate a lot depending on the weather. Then we can turn the thermostat up or down.
jay2003
San Joaquin Valley, California
Posted: 08/20/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Running your A/C has no bearing on whether the temp of the fridge gets any colder. Evaporative fridge units can only really cool about 30-40 degrees below the ambient air temperature surrounding the cooling portions of the fridge (basically the outside air temp). This is why they sell fans to mount in the rear of your fridge to keep more air flowing and hopefully cooling the compartment where the burners are.
What I find helps on hot days (since I don't have a fan) is to throw some blue ice blocks in the freezer then when it gets hot out in the afternoon transfer them to the fridge compartment. Helps keep the fridge down around 40 on those really hot days and keeps things from spoiling.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Hamops
Oshawa, ON, CA
Posted: 08/20/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Absorption type fridges become very inefficient at temperatures above 80 degrees F. To improve my fridges efficiency, I installed two used 12V computer fans to blow air onto the coils and improve the air movement in the fridge chimney. With my fans, I can keep the fridge to less than 40 degrees with daily temperatures in the 90's.
It's possible that you had a bought some marginal milk but if the temperature of the fridge had been low enough then it probably would have survived at least one day.
Helen & George VE3INB and Max (Bichon Frise)
06 Silverado LT 2500HD D/A
2006 Crossroads Cruiser CF30SK
Prodigy Brake Controller
16K Reese Slider with
a Bedsaver
flaja
anywhere,usa
Posted: 08/20/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I always put the milk in the freezer before I leave. Once home I let it defrost in the fidge. I'm a coffee drinker & nothing will ruin the start of my day like sour milk :-(. Sometimes milk goes bad before the xpiration date from improper handling at the store before it even hits the shelf.
  • Roy & Jacqui
  • Retired firefighter & X-ray Tech
  • 2003 Fleetwood Revolution
  • Fulltimers since 2004
Airbus 9e
Rochester, NY
Posted: 08/20/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I was just going to say that....
2004 Dodge Ram 2500 QuadCab 4X4 HEMI
2004 Cougar 285 EFS Fifth-wheel
....and a Dachshund named "Walley"
..."can't sleep.....clowns will eat me."....
