marka123
Poland, OH
Howdy,
I've got an '84 Pathfinder class A. The water heater & other plumbing is all done with plastic hose, on the order of 3/4" OD (I've not measured, that's a guess). Looks like most of the connections are a crimp connection, presumable done with special tools, etc.
I'd like to add a valve, so that I can shut off water to the hot water heater while still having water to the rest of the RV. What do I need to do for this? Can I get valves that will mate up to the plastic stuff? Compression fittings for those or glued or ??
I've done the typical DIY stuff with threaded & sweated fittings for normal home plumbing, but haven't ever done it on an RV. Appreciate any pointers.
Thanks!
Mark
ejforwood
Littleton (Denver) Colorado
Home Depot. I believe it's called Pex. You can get Shark fittings that are like compression fittings or just use the regular glued together fittings that you now have. There are gray fittings and pipe that are usually used in homes and almond colored ones. I have the almond colored pipes in my rig.
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
Bonefish
Midland, TX
It should be stamped on the PEX pipe. I believe fitting are based on the inside diameter. Will save yourself a few trips.
Bonefish
Wherever I happen to park
First.. You should already HAVE such a valve, it's your water heater bypass valve. It may be a single valve with two or 3 positions (Normal/Bypass(Off)) or it may be a collection of 3 valves in what looks like an "H" configuration (Two go to the water heater the other valve is a cross over) but you should already have them
The valves themselves are standard hardware store items, any hardware, plumbing shop, lowes, Home depot and such has 'em in stock.
The connectors are likely PEX and you can get those at an RV store GET THEM FIRST so you get the right size valve
ejforwood
wa8yxm wrote: First.. You should already HAVE such a valve, it's your water heater bypass valve.
Don't be so sure. It was built in 1984!
marka123
Poland, OH
Howdy,
Yeah, there's no water heater bypass setup at all. If the water pump is running, the water heater is getting water.
What's the point of a water heater bypass setup (that feeds the hot lines with cold water when the water heater is bypassed) vs just having a shut off valve on the suppy line to the water heater? Is it just so that you can get water from the hot taps as well? I don't care about that...
The pipes don't seem to have anything stamped on them. They're grey, and the connections look to be either glued & crimped or just crimped together. The water heater & faucet & such have threaded connectors. Still sound like PEX?
Thanks for the help!
Mark
itsalleasy
A bypass will let you winterize the hot water lines past the water heater without filling the water heater. If you are going to install 1 valve I would install all 3. You will save the money the valves cost by not using so much antifreeze.
If it is pex it will have bands at the fittings, and if it is gray it is probably pex.
ejforwood wrote: wa8yxm wrote: First.. You should already HAVE such a valve, it's your water heater bypass valve.
Should, not WILL.. (That's why I said Should.. He should have one, Don't mean he does, DOn't matter when it was built.. Winters got cold enough to destroy heaters in 1984, 1974, 1964 0004. and bypass kits have been sold ... Well.. I know since before 1980 (I can't say when they started selling 'em) since they use an identical kit on home water softeners.
Now: From what the O/P says.. IT appears that though he should. He Don't
So to the OP.. Consider getting 3 valves and doing a full bypass system
greenrvgreen
open road
You don't have PEX, you have PEX's predecesor, polybutylene, which I don't think is sold anymore. And I would be stunned if they're 3/4" OD pipes, but maybe. I'm betting on 5/8" OD, or 1/2".
Lowe's, etc will have valves to tie in, but you really need to bring them a sample, or you'll make multiple trips.
PolyB doesn't have much good going for it; I just tore all of mine out and replaced with gen-u-ine PEX. I bought the horrendously expensive push-on fittings, and my remaining sanity thanks me for it. They work great and were very easy to work with. And expensive.
marka123
Poland, OH
Howdy,
What I have is grey lines, with bands at the fittings. No markings on the lines at all that I can see.
They may well be 5/8" or even 1/2" OD... 3/4" was a total guess from memory.
I'd really rather be able to buy the valves & such I'll need before I start cutting away at the system... If its PEX or polybutylene, is there a way to determing what I'll need by measuring the OD or something else?
I'd really rather add a valve (or three) vs. replumb the entire RV btw... :-)
Mark
