RV.Net Open Roads Forum: installing a DTV converter with a Video Distribution switch
 > installing a DTV converter with a Video Distribution switch
lwasouth
Posted: 08/20/08 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a unit with Winegard's Video Distribution Switch, be advised that the instructions for installation published by Winegard DO NOT WORK. I was following their diagram and had a question, so I called their technical support line. The agreed with my question, and then stated that their method as diagramed, will not work. They suggested a alternate method, either using an A - B switch and a splitter or using 2 splitters. Neither of these methods is exceptable with satellite TV.
Does anyone have an alternate method
Retired2008
Woodstock, MD
Posted: 08/20/08 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I was able to connect it using a splitter from the antenna and running another cable from the converter to the video input on my Sony TV. This was all within my overhead cabinets - otherwise it would have been a problem routing the wires. All my other TVs are set up with a converter box that has an analog pass-thru so I don't have that problem.
Wayne
Bernice
Two - 04 Maltese (Victoria & Albert)
06 Newmar DSDP 4028
04 Honda Element Toad
Road Runners
Tampa Bay, Florida
Posted: 08/20/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I run my HD convertor, satellite and over the air antenn inputs through A-B switches and it works just fine.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
Chris Bryant
DeLand, Florida, USA
Posted: 08/20/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Winegard makes several video switches- some provide power to the antenna, some do not. The hookup would be much different for the 2 types.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Wherever I happen to park
Posted: 08/20/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
If you wish to send me an E-mail (NOT A PM but an E-Mail) I will E_mail you the diagram you need
Moderators. Is there any way or place I can post a JPG here without subscribing to yet another web-photo service?
macira
San Antonio,Tx
Posted: 08/20/08 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a digital box, cd player, and vcr. Inputs from winegard and cable hookup. I switch them all with a switch box. I feed 2 tvs. The only thing left to do is add a second converter so each tv will be able to play a separate digital program. I have a modulator connected to the digital box so it feeds using the coax.
Mac USAF retired
2001 Seaview 32 ft model 8311
Ford f53
2007 HHR
Brake buddy
Falcon2 Towbar
Dick A
Spokane
Posted: 08/20/08 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from General RV'ing forum.
priusron
Tx
Posted: 08/23/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a new LCD HDTV. No converter needed.
Ron
Posted: 08/23/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at an HDTV Digital front end for my laptop... about 60 bucks after rebate at Circuit City.. Hauppauge Win-TV a company with a good reputation.
