RV.Net Open Roads Forum: Fifth-Wheels: Bathroom cabinet tri-light dead
 > Bathroom cabinet tri-light dead
Irma
Saskatoon, SK Canada
Posted: 09/24/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
The three lights above the mirror on the bathroom cabinet of my 2007 Wildcat won't turn on. All the breaker switches are O.K. Any ideas on what may be wrong? We're not electricians, so don't want to start unhooking wires.
P.S. I've posted a dozen questions on this site this past year, and have gotten excellent advice from all the respondents. Thanks, guys!
I. Peltier
dms
Walburg, Texas
Posted: 09/24/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Irma,
Those lights are 12V. The power to them runs through a fuse. Not a breaker.
Are there any other lights that don't work?
If so, it's likely a blown fuse.
The fuses are mounted in the converter.
- d
2008 GMC 3500 CC D/A DRW 4WD
2007 Wildcat 27BH
2007 Lance 835
uva uvam vivendo varia fit
LadyRVer
Posted: 09/24/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
The 3 lights above the mirror over the bathroom cabinet in my Montana are 120V.
Might try resetting the GFI at the 120 plugs, usually in the bathroom, if your lights are not 12V. The GFI in my unit took out the 120 plugs in the bathroom sink area and the 120 plugs in the bedroom along with the triple light over the mirror.
fuzzbutt
Pittsburgh
Posted: 09/25/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
My 3 lights went out also. They were working intermittantly for a while and then quit all together. The light over my swivel chair and the roof light in the bedroom are all connected together somewhere.
If yours are 12v, I would check the ground and the switch first.
John, Sherry & Sabrina
+ Mowgli (Keeshond) Sunny (Sun Conure) & Lily (Cockatiel)
94 Winnebago Adventurer 34'
04 Nissan Murano
98 Subaru Forester
92 Honda Gold Wing
Now.....bring me that horizon.
Fire5er
Port Orchard, WA
Posted: 09/25/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Our unit is 110v and not 12v. If 110v: Check the GFCI to see if the red button is out indicating a trip. If OK then secure the power and remove the light fixture to see if the wires are lose or disconnected. If OK then remove the light switch on the wall and check the wires there.
benb21601
Resident Expert
Posted: 09/25/08 10:21am Link  |  Quote  |  Print  |  Notify Moderator
try this--the light is 12v. the circuit is completed by a flimsy tin plate attached to the inside of the fixture (acts as the ground wire). unscrew the 2 screws holding the fixture on, and examine that connection. it is hopefully just loose. re tighten it, screw the fixture back on and presto-let there be light!
07.5 GMC Sierra 2500HD SLT-Crew Cab Short Box, LMM, SuperGlide, Prodigy
07.5 Jayco Eagle 345BHS-Trip Slide 5er, TrailAir Pinbox, Shocks, Aluminum Tripod, RotoChocks
04 Honda EM5000S Generator
Me,DW,DS,DD,DGSD
Our Picture Page
HUTCH45
NORCAL
Posted: 09/25/08 11:06am Link  |  Quote  |  Print  |  Notify Moderator
As has been said....remove the light and check connections. Wire Nuts can come loose in a 'stick and brick' home, so vibration in a trailer can definitely cause loose connections. I broke a bulb off inside my vanity light and upon removal of the fixture for 'repairs', I saw my connections had been 'wire nutted' and securely taped as well.....
Good luck, and let us know what you find....
Enjoy the journey....
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
scotty63
British Columbia Canada
Posted: 09/25/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have found that solder and heatshrink work better than wirenuts. Most of the 12 volt wiring in RVs uses multi strand wire and due to the nature of this wire wirenuts dont hold. Most times in the 12V system the problem is either a fuse or poor ground.
Having spent 43 years working with electricicity I know the nightmares that can occur. Had a problem with my fiver that I had no markerlights on the front but everything else was working. While it was annoying me trying to locate the missing ground I decided to take a change and replace the freshwater tank that had dropped out of its mounting. When this task was completed my front markers started woking again and no further trouble. Both myself and an RV technician still can't figure how the two were connected but I am not going to lose a lot of sleep over it. LOL
Ron & Jean
Pierre & Kia
British Columbia
Support Crafters and Farmers Markets
Retirement sure changes the meaning of weekend
bluck
Silver City, NM 88061 USA
Posted: 09/27/08 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
some of the new Chineese bulbs solder nibs on the base of the bulb are not high enough to make good contact. Most of the bulb holders now used are also made in China and its not unsual for the springs that push the contacts to the bulb contacts to be very weak and take a set. Either one or a combination of the two can give you problem. The best way is to check with a voltmeter or test light at the bulb holder contacts, no power there most likley a blown fuse.
2004 Chevy.
Duramax-Allison
2004 Thor Mirage
Kawasaki Prarie 700
heaterswa
Plainfield, IL. USA
Posted: 09/28/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Is there a wall switch as well as a fixture switch to enable the lights?
Me, Wife and 3 daughters
TV: 06 GMC 2500HD D/A SLT 4WD / Prodigy / Reese Signature 18K
TT: 04 KZ Frontier 2505QSS-F / Hensley
FW: 07 KZ Durango 315BH / Fifth Airborne / Sidewinder
Ft. Wilderness, WDW.
April 2007
