RV.Net Open Roads Forum: Technology Corner: Analog to Digital Transition FAQ
 > Analog to Digital Transition FAQ
Page of 9
pulsar
Lewisville, NC
Posted: 04/02/10 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
tplife wrote:
tazmangk wrote:
just wondered if anyone knows if they make a 12 volt digital tv?..I camp out in the woods at times and still would like to catch the news, weather etc without the noise of a gen set.
Good luck, digital reception distances are not as far as analog, and that's with a good-sized antenna.
Here is what I posted about our first experience with digital OTA broadcasts.
    In November, 2008, we spend a week at Huntington Beach State Park in South Carolina. Analog reception gave us 1 clear channel and 6 snowy ones. (That was without turning the antenna.) Switching to digital, we received 14 clear pictures and one that was breaking up. (Again without turning the antenna.) Turning the standard batwing antenna gave us 3 good analog signals and 15 good digital signals.
    Several of the channels were from Wilmington, North Carolina. Wilmington is a test market for the FCC; they have gone completly digital, already, and are broadcasting at full power.
    As the crow flies, Wilmington is 85 miles form where we were camped. Of course, this was all costal.
Tom
hotrod4x5
Southern Calif
Posted: 04/02/10 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
In my experience, either works great, or not at all. There is no watching fuzzy channels with digital. It is also much better at night. When I was in Riverside, CA, about 50 miles from Mt Wilson, I got zero daytime reception, well, maybe one channel, that would cut in and out. At night I got 7-8 channels with my batwing.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Yamaha EF3000iSEB (and NOT a GS Member)
SCVJeff
Santa Clarita, CA.
Posted: 04/02/10 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
No surprise out there. There are places in Riverside shadowed from Wilson either by local foothills, or blockage from the San Gabriel ridge in the northern parts. AND some of the station antenna patterns don't tend to have a lot of gain in that direction, more favoring the OC.
Jeff - WA6EQU
mmiille
Iowa
Posted: 01/02/11 08:13am Link  |  Quote  |  Print  |  Notify Moderator
We have two Jensen 12 volt tv's. They work great but are quite pricey and reception is still a problem.
Martin & Cheryl
40 Foot 2009 Damon Tuscany
Two kids left the nest and left the wiener dog.
Full timing since Sept. 2010 so we sold the house in Feb. 2011.
SirKnite
PA
Posted: 07/08/11 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Rather then try to find a digital 12 volt unit I suggest you buy an inverter with the correct amount of watts for a small flat pannel digital tv and power it with a battery that is charged during the day using a solar pannel. This works very well and is not very expensive. Especially if you already have the tv. BTW some people are not aware that you can use a computer flat screen (you can buy used ones cheap) and a converter that will allow tv signals or other video to be sent to it. Last one I bought was about $120 and had a remote control.
mmiille
Iowa
Posted: 07/09/11 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Even though these TV's are $400, I bought them for $80 on ebay. They were take outs from someone else's RV. Got a good deal and a great TV. Problem with these is they don't work on them. Throw away TV's. If something goes wrong they don't fix them when out of warranty. So I'll have to look for another then.
Everet
Posted: 10/11/12 06:22am Link  |  Quote  |  Print  |  Notify Moderator
This article has good info & http://allabouthomeelectronics.com/over-the-air-ota.htmlHow to Videos for RVers on How to hook-up the roof antenna, digital to analog, find the broadcasters before you go on the road...... how to point the antenna for maximum picture quality and program etc http://allabouthomeelectronics.com/over-the-air-ota.html
tomjackson
ohio
Posted: 12/20/12 04:34am Link  |  Quote  |  Print  |  Notify Moderator
It is new information that digital and high definition is not equivalent terms. All high definition signals are digital but not all digital signals are high definition. You can see a digitizing technology in HD broadcasting.
__________________________________
purchase hotbuns in hefty discounts
MrWizard
Traveling
Posted: 01/09/13 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
yes .. many sub-channels are broadcast is SD format and at LOW data bit transmission rates
causing blocking artifacts and pixelation
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Page of 9
