RV.Net Open Roads Forum: Tech Issues: 5th wheel brake connection issue
 > 5th wheel brake connection issue
Tech Issues Related Tips
JodiG
Sanford, FL
Posted: 11/26/08 10:21pm Link  |  Print  |  Notify Moderator
I am periodically losing power to my trailer brakes on my 5th wheel while driving. Obviously, this isn't good as it requires my truck brakes to work too hard to stop the trailer. I've checked the connection and the plug is in firmly. I believe the problem is due to corrosion on the part coming from the trailer that plugs into the socket. The truck socket is new and has no corrosion. Is there something I can do to safely remove any corrosion from inside the relatively enclosed plug on the 5th wheel?
2003 Hitchhiker II LS 26.5 RL
2002 Ford F-350, 7.3 diesel, 4x4, SRW
kaydeejay
SE Michigan, USA
Posted: 11/26/08 10:27pm Link  |  Print  |  Notify Moderator
Quickest surest fix is to replace the plug.
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
JodiG
Sanford, FL
Posted: 11/26/08 10:39pm Link  |  Print  |  Notify Moderator
I thought about replacing the plug. That's my first choice as well. However, I'm hoping to take the rig out for Thanksgiving and was hoping for a quick fix that might help the situation.
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 11/26/08 11:17pm Link  |  Print  |  Notify Moderator
Go to Radio Shack or any electronics store and buy some contact cleaner. Spray it in the connector and plug and unplug several time. That should fix the problem. If no store open try WD40.
dhamblet
Olympia, WA
Posted: 11/26/08 11:50pm Link  |  Print  |  Notify Moderator
Replacing the plug should be a quick fix, taking less than 30 minutes max. I'd do that before taking it on the road with defective trailer brakes.
2005 Dutchmen 35SRV, Pergo, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airbags, Pacbrake, Britebox, 60g aux fuel tank
04 Harley Ultra, 05 CanAM 400MAX Quad
Spending my kids inheritance
wittmeba
Roanoke, Va
Posted: 11/27/08 05:06am Link  |  Print  |  Notify Moderator
The plug may be the best and right answer, but sometimes just removing the plug, cutting back the wires to a new clean area can help too. The section of wire just exiting the plugs (both ends) is most subject to damage as this is where it will constantly flex.
To my loving wife, Carolyn:
"I dont love you because I need you. I need you because I love you".
Truck Trailer Scale Calculator Applet
RV MFgs
Brake Controllers
RV Links
Wherever I happen to park
Posted: 11/27/08 05:45am Link  |  Print  |  Notify Moderator
There are wire brushes you can get, DISCONNECT the rig's battery before using one.
However replacing the plug is such a hard job that it will take you longer to drive to the store, select and pay for it, and drive back home than it will to install it. (Less than one hour labor) The two hardest parts of the job are opening that dang plastic bubble pack, And of course parting with your hard earned dollars at the parts counter register!!!
Also check the trailer to tow vehicle ground Just on my own hardware I've seen a lot of bad grounds.. Usually the chassis end of the ground wire on the tow vehicle.
JodiG
Sanford, FL
Thank you for your suggestions. Since I am not skilled in working with electrical connections, I will look for contact cleaner or try WD-40 and see what happens.
ford truck guy
Pennsylvania
Posted: 11/27/08 06:21am Link  |  Print  |  Notify Moderator
Buy some di-electric greese, apply this to the plug after cleaning. That will help with the cunductivity....
Joe and Lori
2009 Ford F350 SD 6.4*** It's here !!!
08 Montego Bay
Hers are my pictures
Dusty R
Charlotte Michigan 48813
Posted: 11/27/08 08:29am Link  |  Print  |  Notify Moderator
Di-electric means a non conductor. It will keep the connectors from corroding, but the have to displace it to make an electrical connection. It is harder to find but there is some grease/paste that is used on all joints/connections using aluminum wire. It is a cleaner and prevents corrosion. This will do a much better job. One brand that comes to mind is Nolox.
Dusty
