RV.Net Open Roads Forum: Class A Motorhomes: Oasis Elite Door Awning Problem
 > Oasis Elite Door Awning Problem
william.purcell
San Antonio, TX
Good Sam RV Club
Posted: 11/28/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
While retracting last night, the awning sprung all the way out. The motor responds to the switch, but the roller does not move to pull the awning in. For now, I have pushed it in and strapped it closed. From another great post on this forum, I believe the problem is with the roller end cap on the motor end. If so, PPL does have the part. I'll need to get it all apart to confirm what is actually wrong. Has anyone had experience with tearing this beast apart? Any tips would be greatly appreciated.
Bill Purcell
2008 Allegro Bus 40 QDP, Spartan Chassis
lbligh
Good Sam RV Club
Posted: 11/28/08 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I know that this does not answer your question, but is it not under warranty?
Safe travels.
L. Bligh
2006 Tradewinds - 40C
Wingman02
Kitty Hawk, N.C.
Posted: 11/30/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I removed the awning from the MH to repair ours. If you are comfortable on a ladder and can take stuff apart while remembering how it goes back together .... go for it! I called a dealer and without looking at it, he said the awning would have to be replaced .... color matched would be $1,700.00 plus labor.
PPL fixed me up with a part that totaled $100.00 with shipping. Works like it did before the mal-function!
2006 Newmar Ventana 3613
Wells Cargo 8X14 motorcycle hauler
(2) GL1800 Goldwings
(2) CRF230F off-road bikes
(2) Liquid Logic Kayaks
(1) Yamaha Rhino
sonora
West Bend Wi.
Posted: 11/30/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Who is PPL?
Wingman02
Kitty Hawk, N.C.
Posted: 12/01/08 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
PPLmotorhomes.com
cramersteve
Atlanta
Posted: 12/02/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I was able to remove one of those Oasis door awnings in a jiffy using a low-hanging branch at 5mph. I was always going to order the bent parts and repair it, but replaced the whole coach instead. Still have the thing - anyone need some parts?
Giff
Michigan
Good Sam RV Club
Posted: 09/30/09 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
How do I remove a oasis elite door awning?
smarking
Largo, FL USA
Good Sam RV Club
Posted: 09/30/09 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
This is exactly the same problem I had. See my post here -> clicky You are correct. The defective piece is called a roller end cap. See diagram on my earlier post. If you can find one they run $90.00 to $120.00 plus freight. I managed to drill a small hole in the pin on the motor and cap and put a SS screw in it. Put it back together & it works. If you want to message me I will give you more details.
2006 Fleetwood Providence
2003 Honda 4WD CRV Toad
Bea PA
Waynesboro, PA, USA
Good Sam RV Club
Posted: 09/30/09 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
We had to replace that cap also several months ago, the part was about $80. We ordered directly from the factory. Took 2 of us to take it down, you have to slide the awning off after you remove the screws. We never use that awning but that piece was worn. Seems to be a common defect with Oasis.
