RV.Net Open Roads Forum: Class A Motorhomes: 2 furnances in one motorhome
 > 2 furnances in one motorhome
mtnman1989
Collettsville, NC
Posted: 12/11/08 06:54am Link  |  Print  |  Notify Moderator
I was looking at a used mh Monday and it had 2 seperate furnances in it. I didnt know mh had 2 furnances in them?
It was a 2000 Georgia Boy Cruise Master.
How many other mh have 2 furnances?
mtnman
rooster
somewhere in the Ocooch
Good Sam RV Club
Posted: 12/11/08 06:59am Link  |  Print  |  Notify Moderator
Probably most of the larger ones.
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
The Texan
Summer: Cascade, Idaho - Winter: Quartzsite, AZ
Posted: 12/11/08 07:09am Link  |  Print  |  Notify Moderator
Almost all over 36' have 2 furnaces and some over 43' have 3 furnaces. We have 2 gas furnaces and 2 electric heat pumps.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 & FT Class of 2002
'05 HR Endeavor 40PRQ, 400 Cummins -With-'05 GMC Sierra LT, CC, Z-71, the pusher & our Arctic Cat 500A & Suzuki KQ 400A, riding in or behind the pusher.
Where the wheels are stopped
CurtisG
Vinton, Louisiana
Good Sam RV Club
Posted: 12/11/08 07:10am Link  |  Print  |  Notify Moderator
My '03 34' Allegro Bay has 2 furnaces.
Curt
CurtisG
2003 34' Allegro Bay
WH(W22)/GM8.1/Allison
bsinmich
Holland, MI
Good Sam RV Club
You can also set different temps for the front & rear of your MH and save on fuel when an area will be unoccupied.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
chasfm11
Dallas/Ft Worth Areas
Posted: 12/11/08 07:37am Link  |  Print  |  Notify Moderator
Ours (see signature) has two Atwood furnaces. It is sometimes a pain to balance between them, where one is not carrying too much of the load. Since we started using ceramic heaters for camping, about the only time that they run is to protect the tanks between uses because we don't winterize. It is 26 degrees here this morning.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
2005 Saturn Vue Toad, Falcon2 Towbar, BrakeMaster Toad Brake
pfunk
Shelby Township, MI
Posted: 12/11/08 08:02am Link  |  Print  |  Notify Moderator
1 furnace 38'9" no problem in the teens and it doesnt cycle that much. Just like a large house, proper setup and insulation you can run 1 large furnace instead of 2.
2000 Holiday Rambler Endeavor
300 Cat 6spd Ally
canttellu
Pennsylvania
Posted: 12/11/08 08:09am Link  |  Print  |  Notify Moderator
Mandalay
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Good Sam RV Club
Posted: 12/11/08 08:44am Link  |  Print  |  Notify Moderator
I have 2 in mine.
SunflyerA
Andover, Minnesota USA
Good Sam RV Club
Posted: 12/11/08 09:44am Link  |  Print  |  Notify Moderator
Two furnaces are a plus....If one goes out your not dead in the water....I've lost one twice.
sunflyer
2005 Fleetwood Excursion 39S
350 Cat
If you are what you eat; then I am fast, cheap and easy
