RV.Net Open Roads Forum: Can't see pictures because of preferences - tutorial
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Can't see pictures because of preferences - tutorial
pulsar
Lewisville, NC
Posted: 12/31/08 05:00am Link  |  Print  |  Notify Moderator
Because some members use slow connections, the forum software allows you to opt out of viewing pictures. You can change this setting on your preferences page.
  • Click on the "My Forums" link located in the upper-right portion of most forum pages.
  • Click on the "My Preferences" link located in the list of links that run horizontally across the window.
  • At the bottom of the General Preferences section, you will find 4 check boxes. The third one governs whether or not you will see pictures in the body of posts.
  • While you are on you preferences page, check to see if you want to make any other changes.
  • After completing changes, scroll to the bottom of the page and click on the Submit Changes button.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
