RV.Net Open Roads Forum: Class A Motorhomes: air bag valve replacement
 > air bag valve replacement
rooster
somewhere in the Ocooch
Good Sam RV Club
Posted: 01/05/09 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Hoping I can "go to school" on all the mechanics out there.
Seems I have a leaking valve on my pass side front airbag.I had it diagnosed at a repair shop on the road. I'm now wintering in Texas and wondering if replacing that valve is something a novice could do. I'm fairly handy with tools, but, didn't bring many along.
I also had my dash blower motor quit working. Checked the fuses, but all were good. No loose wires either.
Any help anyone can offer me would be appreciated.
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
Randy972
UPSTATE S.C.
Posted: 01/05/09 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Hey Rooster,
Sorry about your problems.
I replaced the air valves on my coach a few years ago. Found them on net cheaper than locally. My valves were just a simple disconnect air lines and wire and bolt on new valve. I have older coach so mine maybe somewhat more simple than new coaches.
Good luck.
Randy
Gulf Stream Friendship Diesel Pusher
Honda Accord
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 01/05/09 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Your dash blower problem could be the resistor for variable fan speed. Most are located on passenger side where the navigator can hit them with their foot. It may have the connector knocked off.
Your air bag may have standard valves and it could be loose or if you got valve extension lines the small flat washer has gone bad. Some shops have these little seals. If it is leaking where the stem goes into air bag, new air bag time!
Bud
Suzuki XL7 pushing Pace Arrow
Sully2
Cincinnati
Good Sam RV Club
Posted: 01/05/09 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Ride height control valve for air ride suspension???
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
HippiDude
Mt.Airy, MD
Posted: 01/05/09 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Should be a simple matter of disconnecting the lines, just mark the lines with masking tape and un bolting the valve. You don't want to switch the lines or the air pressure will stop at the valve. Also make sure there is no air pressure in the system before you start.
