RV.Net Open Roads Forum: Class C Motorhomes: Does propane reduce gas mileage?
 > Does propane reduce gas mileage?
Class C Motorhomes Related Tips
stevebarley
burlington
Posted: 02/09/09 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
While having my battery draw checked at the shop they told me I should have the propane stuff removed from my engine cause it reduces the gas mileage when using gas (the propane system doesn't work anyway). They can't give me a price cause they don't know all they need to do until right into the work. Is it true by leaving some of the propane stuff in place my mileage will be worse?
Hopefully 1 day (soon) I'll get everything sorted out. Thanks
Steve
sjptak
Seymour, CT
Posted: 02/09/09 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
?? I'm not understanding the question. What propane stuff do you have connected to the engine? When you say the propane system doesn't work, are you saying your stove, furnace, hot water heater and fridge won't run on propane? I'm confused....
Off to See the Lizard
'99 Four Winds 30' Class C
'97 GEO Tracker
'63 Honda 305 Dream
1947 Wife
1949 Me
LadyRVer
Good Sam RV Club
Posted: 02/09/09 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
This should be interesting! How/what propane stuff needs to be removed from engine? I can understand "if" you took off the LP tank(s), LP appliances you might be a few pounds lighter, but I wouldn't think that would be enough to make a difference in mileage. Plus, if you decide to trade later on, buyer would prefer to have the LP appliances left in and have the system checked and fixed. But, I have never heard of propane stuff being removed from an engine.
Will be checking back to see other responses.
utahlanman
Salt Lake City, Utah
Posted: 02/09/09 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I concur with sjtpak. If it's not related to the engine (ie.. gas, stove, furnace), then it will have no bearing on power/performance.
Perhaps they're naively suggesting that the extra weight of the propane tank will cause extra power consumption -- and if so, they are wrong to indicate that something so small would effect power.
2005 Jayco Greyhawk 31SS
2005 Kawasaki Bruteforce 750
2001 Kawasaki Prarie 400 4x4
2000 Honda Rancher 350 2x4
Mandalay Parr
Phoenix, AZ
Good Sam RV Club
Posted: 02/09/09 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking the engine has been modified to run on either gas or propane or natural gas.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
NRALIFR
Middle Earth
Posted: 02/09/09 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Jeez guys, pull your heads out. He has an engine that at least used to be able to run off of LP or gas. A bi-fuel engine.
2001 Lance 1121/1995 F-350 PSD CC DRW. Many mod's and upgrades. See my Profile page.
denisondc
Alexandria, VA USA
Posted: 02/09/09 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I think the poster was referring to an engine that had been set up to work on either propane or gasoline. I cant imagine the propane parts (the control/mixture valves, the heater exchanger to pre-heat the propane, the propane tubing and pressure regulator, would cause any difficulty to running on gasoline - other than a little added weight. But there are many different schemes that have been used in making propane-or-gasoline burning engines, that you would have to look at the actual engine and look for something that would upset the efficienty when using gasoline.
72 Winnebago D22T
LadyRVer
Good Sam RV Club
Posted: 02/09/09 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
As I was reading another post, I happened to think NRALIFR that is probably the case..if so, if that were my truck, then I would definitely have the LP system taken off.
stevebarley
burlington
Yes it has an engine that was dual fuel (gas or propane). Sorry for the confusion.
Xpltivdletd
WV, U.S.A.
Posted: 02/09/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to seek a 2nd opinion. I'm guessing you have gasoline via EFI, with the Impco® Mixer on the intake. How cobbled or how professional in installation was this? If you are not sure, you may want to find somebody who knows more about it than anyone you have asked so far.
If the Impco® is sized for your engine and your EFI is working properly, it should not have a significant effect (I think). There could be a few advantages to getting the LPG made right, instead of taking it off. But you need to have it seen by someone who understands it.
