Bumpyroad
Virginia
Quick trip wrote: Correct me if I'm wrong, but if you drive onto these levelers aren't you leveling side to side?snip!
winnie does not make a TT or 5er which sounds like what you are talking about. I wondered why winnie didn't get into pull behinds, just buy out a closing manufacturer.
bumpy
Kamphiker
South Florida (this 'aint paradise anymore)
Bumpyroad wrote: Quick trip wrote: Correct me if I'm wrong, but if you drive onto these levelers aren't you leveling side to side?snip!
bumpy
Well Bumpy Winnebago did make Travel Trailers back in the 60's and 70's
this one is:
Mored pictures with inside of a restored:
'61 Winnebago Travel trailer with Overhead bunk like a "Class C"
In addition to my Home Made Ramps, I have a "case" of the Lynx/Lego plastic levelers for on the road as they are light and take little space to store. I also carry a couple of short 2x8 & 2x10's as you never know when you will need them
edited 03/14/09 06:44am by Kamphiker *
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->Elkmont Summer 2009 slide show
NEW-> Memories of OLD Miami, Fla. (pictures)
Bumpyroad
Virginia
Kamphiker wrote: Bumpyroad wrote: Quick trip wrote: Correct me if I'm wrong, but if you drive onto these levelers aren't you leveling side to side?snip!
bumpy
this one is:
yes, I said "does not make", not did not make. I have been at the plant and seen the old TTs on display.
I suppose it is possible that a winnie TT is still on the road.
bumpy
Camper Ken
Oregon
PapPappy wrote: Also saw where you could add some dowels to the bottom of the ramps, so that you can put two side by side (and have them basically lock together) for the back tires.
Did you see that tip in the newest issue of Motorhome magazine?
2007 Winnebago Access 31c
2006 Ford E450 chassis
LouInNM
Las Cruces, NM
Bumpy, I put a couple side by side and they cover my duals pretty easily. Actually, right now I've used an entire set to level one side of my mh.
SAR41
Evanston,Wyoming
Good Sam RV Club
I have used these for about 3-4 years now. Have been very happy with them. Have 4 of them so that I can cover duals on rear and two fronts or just both duals. Have never needed more. Had some I built out of wood, very heavy, always breaking and having to rebuild. Plastic much lighter and have not had a problem with them breaking. Had the lynx lego ones, after shattering a few of them with the weight of my Class C, gave them to a friend that had a TT.
Camco Tri Leverlers. About $ 18 each.
If it aint broke don't break it If you do HIDE IT!
30'Coachman E-Superduty Triton V-10 03 Ranger Toad
2 Vino 125 Scooters 500 Polaris ATV 200 Honda ATV
670 Summitt SkiDoo Snowmobile and NOT ENOUGH FREE TIME!
Wife & I with Chein(Pitt Bull,just a big baby)
maddog348
Bakersfield,CA
Good Sam RV Club
Made some about 10 years ago. Used 1 1/8" flooring plywood cut in 8 1/2" wide strips. Lengths very similar to above diagram. Varnished - sprayed rubber coating on bottoms - to keep from sliding. Still using about 25# of them.
Quick Trip, My ClassC did NOT have levelers. Used appropriate # of blocks on which ever (1-3)tires/corners needed raising. (Just like your TC)Why assume all MH have levelers?//
(OP's sig/profile is photo ClassC - looked before I answered.)
edited 05/27/09 09:32am by maddog348 *
JAXFL
Jacksonville, Florida, USA
For leveling side to side I have the orange level blocks that were mentioned before if I only need 2 inches of lift but I really like these. I got 4 Camco Tri Levelers from Tweetysfor $14.44 each + shipping. The first time out was a GA state park that the site was not level and they were fantastic and very easy to use.
