Jdandt
Visalia, Ca
Taking my trailer to Shaver Lake/Camp Edison here in the Beautiful California Hills for the first time out this year.
Question:
There is still snow on the ground and temps are about 50f high and 20f low. Will my trailer with the heat on etc. be enough to keep my water/lines from freezing?
2005 F250 TD Lifted 4X4 37" Tires "The Beast"
2008 CrossRoads Zinger 29ft.
4 kids WoOt!
joebloe
Illinois
For a few days? Yes you should be fine.
smkettner
Good Sam RV Club
Do you have exposed pipes such as low point drains and outside shower?
Hookem2004
Milpitas, CA
If you have a exposed pipe from your water tank then it goes through the floor somewhere to the water pump, put a piece of foam pipe insulation on it.
2006 302 Skyline Rampage TH
2006 3500 Duramax CC/Dually
2004 2500 Suburban
2000 1950 Lund Tyee 200HP Yamaha HPDI
Bull Rider
Washington, The State
Our trailer has the enclosed underbelly option (kind of like me) and one of the heat ducts terminates in the underfloor area. So, if you have that too, you should be OK... If not, you're probably still OK, I'd leave the cabinet doors open where you have plumbing just to provide a little more heat into the areas with piping. Your hot water tank will be fine, cause it's on and heating. Good Luck..
Hornet28BHDS
Parker, PA
Good Sam RV Club
How long will it be in the 20's? If it's only going to be down there for a couple of hours, then you should be fine with the heat running.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
skipnchar
Topeka Kansas USA
You MORE THAN LIKELY will be fine that way but no way for anyone HERE to say for sure. Most RVs loose enough heat to even heat a non enclosed belly enough to protect when temps are in the mid 20s AND no wind is blowing. If your trailer is better insulated AND it's windy out AND it stays at 20 degrees for very long, you could have a problem. The proof is ALWAYS in the details. Probably the weak points to watch are the water hose and possibly the dog shower.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
