pardad
Sweet Home Alabama
While working this morning a blue tint appeared on my screen. It's just like someone had put blue plastic wrap over my monitor. I know it's not the monitor - I can turn the computer off and the color on the monitor goes back to normal when I run the built-in set up and diagnostic.
So far I've done a restore to yesterday. I've downloaded the latest driver for my video card, triple checked the settings, rebooted several times and scratched my head even more times.
Specs are: Vista Home Premium. AMD Athlon 64x2 Dual Core 4200+ 2.2GHz. 2GB Ram. NVIDIA GeForce 6100.
Can any of you think of anything else I can check or do other than replacing the video card?
UPDATE: Started checking connections and then the cable. The puppy found a new chew toy. Problem solved. Thanks for the suggestions - got me to look at the simple fix first.
Thanks,
edited 04/03/09 07:38pm by pardad *
Dennis
"They can change their minds but they can't change me"
eubank
Angel Fire, NM, USA
Are you running up-to-date security software?
Lynn
http://forum.aardvarkrv.com/blog/
Hayduke Lives!
oldham
Cameron, NC
Good Sam RV Club
My screen went purple this morning. It was caused by a loose video cable connector on the monitor. I jiggled it a little bit and the colors returned. May not be the same problem as yours but is worth a try. Good Luck
Jack & Marie
Good Sam Life Members
Amateur Radio -K4FRU-
WeeWillie
North West Florida
Try reseating the video card and replacing the video cable. Do one at a time. You can also try booting into safe mode. It sounds like a bad video card. Good Luck
Gary, June and Frisco
bishopdave
Today - Texas
Video cable (loose perhaps) or monitor going bad.
Dave Bishop
FT since 2002
weasel4
Alberta
pardad
Depending on what type of monitor you have. If it's the old CRT type you probably have a color gun that went dead.
BTC
Eagles may soar, but weasels don't get sucked into jet engines.
Rick Jay
Greater Springfield area, MA
I would check the video cable connections to make sure they are tight. (Screw in those thumb screws!) If that doesn't fix it, try "wiggling" the cable to see if that changes anything. If not, then I'd check the video card (if so equipped) to make sure it's securely seated in the expansion slot. If possible, you might be able to try a different video cable.
If still no joy, see if you can borrow another monitor from someone to see if it still does the same thing. If it does, it's most likely a video cable or card issue. If this fixes the problem, then you probably need a new monitor.
~Rick
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (12-Angel, Lexi96.org), 1 girl (8), 2 boys (9 & 6).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
wittmeba
Roanoke, Va
Try this:
Right click on the background
Select Graphics Properties
Select Color Correction
Slide the brightness left (most likely)
Does that help?
To my loving wife, Carolyn:
"I dont love you because I need you. I need you because I love you".
Truck Trailer Scale Calculator Applet
RV MFgs
Brake Controllers
RV Links
Admin
Channel Islands Harbor, Ca.
Administrator
Bad cable or card.
Just went through the same thing.
Kind of a blue/purple tint
I had just switched the monitor to my backup computer.
Found a bent pin - straightened it and all is well.
Admin
