RV.Net Open Roads Forum: Towing with a Super C Kodiak chassis
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Towing with a Super C Kodiak chassis
Class C Motorhomes Related Tips
ronfisherman
SE Michigan
Good Sam RV Club
Posted: 04/09/09 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
crop guy wrote:
I finally took the time to run my Seneca HD36FS over the scale it weighed 21,400, 2 adults, 4 kids, 1/4 tank of water, full fuel, I was surprised the weight was that much.
Same thing I found. Did you get a weight of rear axle only?
crop guy
Monroe, Georgia
Good Sam RV Club
Posted: 04/09/09 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
FRONT AXLE 6940 LB
DRIVE AXLE 14,460LB
Texas TC
Corinth,Texas
Good Sam RV Club
Posted: 04/10/09 08:18am Link  |  Quote  |  Print  |  Notify Moderator
That is one of the reasons I went to the International chassis when I sold my Kodiak chassis Four Winds Fun Mover. Being a class 6, the International has a GVWR of 25,999# and a GCWR of 33,000#. My 34' weighs in on a CAT scale at 21,600# fully loaded with food, clothing, gear, 2 people, 140 gallons of fuel and 100 gallons of water. Holding tanks were empty. Front axle weight was 9,180# and rear was 12,420#. I know this discussion is about the Kodiak but I wanted to give a comparison to the class 6 vs the class 5 chassis. Chevrolet builds a class 6 Kodiak chassis but for some reason, the RV industry has not embraced it. I think that is a big mistake. As Ron and others have shown, the class 5 5500 Kodiak chassis is at or almost at capacity when loaded for the road.
2008 Gulf Stream SuperNova (6331)
mfa
Good Sam RV Club
Posted: 04/12/09 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Texas TC wrote:
... As Ron and others have shown, the class 5 5500 Kodiak chassis is at or almost at capacity when loaded for the road.
It all depends on the make and model. I have a Gulf Stream 33-foot model 6316. Heading out for a trip fully loaded with full gas and fresh water, my unit weighs 17,780 lbs. That still leaves me 1,720 lbs Cargo Carrying Capacity.
stb130
South Jersey
Posted: 04/14/09 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Go for any of the Kodiak units, you will have no problem with 6000lb.
http://stbracing.blogspot.com/
1kwik72
Lansing MI
Posted: 04/15/09 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
With the trailer loaded to the hilt with more fuel than I normaly carry, The race car, Quad, tools & equipment it was just under 10k. With the coach full of water propane and fuel, plus food, 3 adults a 1yr old, and all associated gear total weight was 27,700 (about 1700lbs over) I weighed it worst case senario. I figure most days I am right at the GCWR. It tows great, it could use a little more power but what couldn't at that weight.
Craig
2008 Gulfstream 6316 Super C
az99
N.Y.
Posted: 04/15/09 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Craig
How do those new Strange rotors work ?
morkable
Alberta
Posted: 04/29/09 08:05am Link  |  Quote  |  Print  |  Notify Moderator
From what I have been learning, the issue for towing on the kodiak chasis is not the frame, suspension, or axles. They are all plenty strong enough to tow 10 -15k lbs. The issue is the Allison 1000 tranny, which is the same tranny that you would have in your pickup. This is what cuts down the towing capacity of your unit. I personally wouldnt be too worried about this, I am seriously thinking about buying a seneca 36ms, and I will be towing 10000 lbs with it. I will be adding a deep pan and watch the guage when going over hills.
JMHO
Kevin
paulin
No. CA
Posted: 04/29/09 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I will be adding a deep pan wrote:
I assume this is a deep pan for the transmission. Is one available from GM or is it from aftermarket suppliers?
Paul
Paul & Linda
2007 Jayco Seneca HD 34SS Duramax
2005 Saturn VUE
"Monty", "Maggie" & "Murphy" the mighty Shih Tzus
FMCA #F375077
bowtiebill
Fillmore, CA
Posted: 04/29/09 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Check with B & M, TCI, and Bully Dog. All make deep pans.
Bill, Sherry, & Murray
2005 Gulfstream Super C
