RV.Net Open Roads Forum: Towing: increase towing capacity
Search only in Towing
Open Roads Forum  >  Towing
 > increase towing capacity
melcole
home
Posted: 04/19/09 10:45pm Link  |  Print  |  Notify Moderator
I have a diesel pusher on a freightliner chassis it has a 10,000 pd towing capacity how can I increase this? Here are some things I've been told 1. change the rear diff it has a 17000 pd change it to a bigger one.
2. increase the rear tire size for greater load handling.
3. put a wheel assist on the trailer tongue.
Does anyone have any idea what will work?
blt2ski
Kirkland, Wa
Posted: 04/19/09 10:59pm Link  |  Print  |  Notify Moderator
I would suspect you issue is the hitch itself! assuming a hitch is installed. Another problem with some MH;s, altho probably not a pusher style, is the LONG overhang, and additional length add by the MH manufacture. I do not think this is an issue with a pusher.
In the end tho, trailer tow capacity is not a given. I personally do not follow them. but use as a guideline. Otherwise, why are two rigs, same chassis, one with a 5000 lb capacity, the other 12K lbs, what basic differences is there? NONE other than a motor, and axel ratio. Some cases only an axel ratio. So this tells me tow ratings are nothing more than performance factors. SO as long as you know, you will go slower than the factory engineers want you to go to there performance standards, you can go higher.
As far as option #2, bigger taller tires will reduce the overall ratio, making take offs harder, NOT a good option. Reducng the axel ratio, good to bad. If you have a double OD trans, taller ratio's, not too bad, but if your already on the low end of things, you may make things worst than need be.
Marty
Check RV.Net Blogs at: blog.rv.net
mkirsch
Rochester, NY
Posted: 04/20/09 06:58am Link  |  Print  |  Notify Moderator
What is a "wheel assist on the tongue?"
10,000lbs towing capacity is phenomenal for a motorhome. What are you trying to tow?
You may or may not need to make modifications to tow more. It will depend on where your pusher rig is with regards to its existing capacity. That means you need to weigh it and find out what the axle and tire ratings are now.
wittmeba
Virginia
Posted: 04/20/09 05:18pm Link  |  Print  |  Notify Moderator
Payload/hauling(vertical measurement) and towing(horizontal measurement) are two different measurements.
The rear end change might help the towing(horizontal) but I dont think the tires/wheels will.
The tires/wheels might affect or be affected by the payload/hauling(vertical) capacity. Suspension and tires are in play here.
NRA Member & supporter of the 2nd amendment - over 5,000,000 strong
Firefox® 33
Log home images - Updated 05/19/2013
LIKE2BUILD
Decatur
Posted: 04/20/09 08:54pm Link  |  Print  |  Notify Moderator
I've seen a couple of different brands advertised on the net, but I could only find this Hitch Helper in a quick search. I've seen others with dual tires and higher load capacities, but this gives a good idea of what he's talking about.
2012 Sandpiper 32QBBS
'14 Ram 2500 | Crew Cab Long Bed| 4X4 | Cummins TurboDiesel
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (18, 11, & 10)
1 forgiving wife!!!
melcole
home
Posted: 04/20/09 10:29pm Link  |  Print  |  Notify Moderator
In addition to my 1st post I have 35.5 class A on a frieghtliner chassis and I want to pull a 30 foot stacker trailer with 2 cars,a quad and tools. The trailer wieghs 18000 pds loaded but the motorhome is rated to pull 10,000 pds I need to know how to get the motorhome up to 20,000 pds please help.
Londo13
Hammond
Posted: 04/04/10 09:32pm Link  |  Print  |  Notify Moderator
I think this is what he is refering to;
http://trailertoad.com/index.html
This removes the tongue weight but doesn't help with the stopping power. And frame strength is still an issue in the long term.
Bruce & Tam
2 Fur Kids (Labradorables) Troyer & Wiseco
Going Full Time in the Near Future
"Never argue with Idiots. They will just drag you down to their level and beat you with experience."
blt2ski
Kirkland, Wa
Posted: 04/20/09 10:33pm Link  |  Print  |  Notify Moderator
Do you currently have a hitch installed? if so, what is the capacity of said hitch? if 10K lbs, then that is your problem. Get a hitch good to 20K lbs, Which in reality, will probably be a pintle style hitch vs a ball mount. You may also have to have said hitch custom made to your rig.
marty
JIMNLIN
Oklahoma
Posted: 04/21/09 05:59am Link  |  Print  |  Notify Moderator
have you been to Freightliner or the DP manufacture for their input on doubling your equipments towing capacity.
I'm sure folks on the class A forums with a DP may have info for you. Check them out.
