Baidy
Walkerton On
Can any one tell me where I can buy the new style bunk latches to replace the knob setup? In Ontario if possible. They look and work so much better than the screw knobs.
Coyotecprs
chicago
Baidy wrote: Can any one tell me where I can buy the new style bunk latches to replace the knob setup? In Ontario if possible. They look and work so much better than the screw knobs.
Here is the information I have from somebody that posted it a while ago.
You can also order them directly through Fastec Industrial. P/N 65004-100 (cargo vise, bar lock handle, white powder coat)$10 each and P/N 65006-100 (bar lock, white powder coat)$6 each. Ask to have them keyed alike. They don't come with the little foam pad on the back, but she said she would give me some rubber material to use. You have to supply your own hardware. The number is 1-800-837-2505 ask for Felicity "Flip" Miller.
Installation is pretty straight forward. Remove the old screw latches, figure out what hardware you're going to need (either nuts & bolts or lag bolts, etc). Drill your appropriate sized holes for mounting the lock set and the lock handle. caulk to seal up any exposed holes and you're good to go. Look through all 6 pages of this post for pictures and you'll get the general idea of what you need to do.
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
bamaram2002
Central Alabama
FWIW - Felicity "Flip" Miller is no longer with Fastec, but they still have people to help you. It also took me about 3 tries through out the day each time I called to get anyone to answer. Some days I never got an answer, so be patient and keep trying.
As for mounting the latch itself, it is best to use T-nuts so that you don't have a bolt and nut protruding through the bunk door to tear up your mattress.
Mike, Michele, Hannah (13) and Elijah (10)
2002 Dodge Ram 1500 QuadCab
2003 KZ Coyote 23CT
Family Travel Photo Album
Robmoo
Dallas. Texas
That why placing my order just now was so easy. I was following in your foot steps so she already knew what I was ordering. I can't wait to install the new latches. For under $100 and a couple of hours of my labor they will be well worth the money and effort.
2006 GMC Envoy I6 4x4
1997 Seadoo Speedster twin 85's
2002 Travelstar 23RBS -The year before Starcraft started listing bunk sizes honestly-
firefighter938
Ohio
I called the Lock Division of Fastec Industries today. If you call there direct # they answered right away 1-574-266-9374. I talked with Debbie and she was very helpfull and said they would be shipped by Wendsday. $16.00 a set plus shipping. I will update when total comes in.
soneill5
Swartz Creek, MI
When needing to screw into the bunk end to re-fasten the tent support I found myself screwing into nothing but insulation.
Are these latches indeed that easy to install? Do you need a specific location on the bunk door or trailer?
'11 Keystone Cougar 31SQB
'08 Chevy Suburban
Me & Wifey '67
Erin '98, Morgan '99
Pooch Bailey '96, Pooch Sadie '07
Robmoo
Dallas. Texas
That's all these campers are is a big Styrofoam cooler with a bit of fiberglass, thin plywood, and in some places thin aluminum.
tupfam
Colchester, CT
soneill5 wrote: When needing to screw into the bunk end to re-fasten the tent support I found myself screwing into nothing but insulation.
You can use 'T' nuts on the inside of the bunk ends. They will be flush on the inside. I had to use backing plates on the inside for the latch arms as there was only fiberglass & styrofoam.
Pretty easy install once you figure out all the hardware you'll need and whether or not you need shims and backing plates. I installed them at the same location as the screw knobs that I removed.
'02 Ford F150 SuperCrew 5.4L Triton
'07 Gulfstream Conquest 25RSL
bamaram2002
Central Alabama
This post might help. There is a link to another thread that shows the inside of the bunk door in an installation using T-nuts. I also spelled out the hardware I bought to install the latches in there.
If you don't have a stud at the edge of your door frame to screw the handle mount into, you'll need to drill through the wall and use a plate or large fender washers on the inside - using bolts instead of screws.
pointbrze
Coltons Point, Maryland
I also had my latches replaced, thanks to happycampin4 and tupfam! I bought everything and gave it to my RV repair guys. . .they did an awesome job! Just a note: I bought a white 1/4" pvc strip from Lowe's (it was with the household exterior trim pieces) as the backer plate on the inside and also for the shim on the outside. I didn't have to paint mine since it was white already (and the perfect size). I think it was the BEST mod ever! Opening and closing is so much easier now!! I think the pics are in my signature below.
Me- Cindy
DD- Stephanie
Sometimes DS- Mark
1 spoiled LhasaPoo- CoCo
2004 Starcraft TravelStar 21SSO
2003 Toyota Tundra V6
Pics
