RV.Net Open Roads Forum: General RVing Issues: water temp fluctuations
 > water temp fluctuations
jpeterman57
Georgia
Posted: 06/03/09 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
When using on board water in my 2004 Fleetwood Prowler 24BH, the temperature fluctuates at all faucets hot/cold as the water pump cycles on and off.
Also the kitchen sink faucet sputters air when turned on initialy. I suspect this is because of an air leak in the faucet area but the water temp fluctuation has me baffled.
-Jeff
2004 Fleetwood Prowler M-240BH, 2006 (modified) Tundra XSP, Yamaha EF2400is
"May the forces of evil get confused on the way to your house"
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Good Sam RV Club
Posted: 06/03/09 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
when the faucet sputters it just air in the lines, keep running and it should clear. The temp, if it just for a minute is just the difference in temp between the tank and the lines, if your run it for a few min does it get warm?
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
jpeterman57
Georgia
Posted: 06/04/09 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
Water never actually gets hot. Stays lukewarm in gas or electric mode. I have been advised there is a water heater bypass valve that is probably left open and needs to be closed. I'll have to look for it next time I'm down at the farm.
jpeterman57
Georgia
Posted: 06/04/09 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
The water temperature would go hot/cold /hot/cold etc... as you hear the water pump cycle on and off. Weird.
okraman
White Hall, AR, USA
Good Sam RV Club
Posted: 06/04/09 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the hot water heater bypass valve is open.
2004 GMC 2500HD EC 6.0L 4.10 4X4
'05 Jayco Eagle 298 BHS
16' Nova Craft Prospector Canoe
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 06/04/09 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Two likely things… the bypass as already said or if it happens in sync with the pump it might be a faulty check valve in the HWT outlet stuck in the open position…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
jpeterman57
Georgia
Posted: 06/11/09 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Everyone has good points. Thanks a lot!
acker1
fulltimer
Good Sam RV Club
Posted: 06/11/09 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed a new pump and it does the same thing. I'll try the above suggestions.
Thanks
DICK
37'--'98 Endeavor
toad--'05 Crewcab GMC
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
jpeterman57
Georgia
Posted: 07/04/09 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Pulled the panel inside covering the water heater and there were two valves. I turned one to open and the problem was corrected.
I think the water heater had been winterized and the valve was never repositioned in the spring.
