RV.Net Open Roads Forum: What size of generator needed to run an air conditioner
 > What size of generator needed to run an air conditioner
baumann6
antelope lake
Posted: 06/04/09 08:44pm Link  |  Print  |  Notify Moderator
What size of a generator is needed to run an air conditioner it is not going to be a very big unit as it is going in a smaller trailer. Thanks
wtravlr1
Palm Harbor, Florida,
Posted: 06/04/09 08:50pm Link  |  Print  |  Notify Moderator
Do you know what the rating is on the air conditioner, guess if its small enough a eu2000, but most seem to need the 3000. Also a hard start option on the air conditioner may help, if you do a search, this topic was done earlier today, it think/
ang
bldrbuck
one or the other
Posted: 06/04/09 09:28pm Link  |  Print  |  Notify Moderator
Anything less than 2000 Watts will not handle most airconditioners. In most cases a Yamaha 2400 will do the job.
The Yamaha 2800 will do the job as will either the Honda or the Yamaha 3000.
There are Kipor and Champion genorators that will also work.
* This post was edited 06/05/09 10:37am by bldrbuck *
baumann6
antelope lake
Posted: 06/04/09 10:02pm Link  |  Print  |  Notify Moderator
Thanks.
tatest
Oklahoma Green Country
Posted: 06/04/09 11:12pm Link  |  Print  |  Notify Moderator
8000-11,000 btu/hr air conditioner, 2400-2800 watt continuous.
15,000 btu/hr air conditioner, 3600-4000 watt continuous.
13,500 btu/hr air conditioner is more tricky. A high efficiency A/C might be OK on 2400 watt. A standard full-height model might be OK on 3KW, or might be trouble. A low profile 13,500 should be on a 3600-4000, because that low profile comes at the cost of making a smaller A/C work harder.
A lot depends on WHAT ELSE in the RV will load the generator. If the load was truly only A/C, then a 2.4 KW (continuous) genset will run any RV air conditioner, because all are sized for a 20 amp circuit.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
chili7
Colorado Springs, CO
Posted: 06/04/09 11:30pm Link  |  Print  |  Notify Moderator
I have a Yam 2400is that will run my 13.5 at 9000 feet. I just can't use the microwave at the same time.
2006 Prowler Regal 285RLS Extreme Edition 5th Wheel
2005 F350 XLT PSD CC SB 4x4 FX4 SRW TowCommand SG2
PapPappy
Wilmington, NC
Posted: 06/05/09 05:24am Link  |  Print  |  Notify Moderator
Check to see how many watts the A/C unit is.
I was just reading a blog about the "portable" A/C units that draw about half the power of the rooftop models....in which case, all but the smallest of gensets might work. It depends again, on what system you have, or plan to get.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
dougford
San Antonio, TX
Posted: 06/05/09 05:29am Link  |  Print  |  Notify Moderator
See this link in the Toyhaulers section:
link
2008 Ford F350 CC 4X4
2012 Jacyo Octane T29A
2006 Yamaha Kodiak
2007 Yamaha Big Bear
2006 Yamaha Blaster
2007 Honda Recon
2006 TTR50
2012 YZ250F
Cruzette
Santa Cruz, CA
Posted: 06/05/09 07:15am Link  |  Print  |  Notify Moderator
We run our one AC without any problem with a Honda EU2000. We can also charge our batteries, run the heater, microwave, TV and anything in the 5er, just not all at the same time. It's fairly quiet and light weight.
After doing a lot of shopping around, we got a great price on our Honda generator at Wise Sales
Check them out and give the experts a call and find out which generator is best for you. 1-800-916-9473.
It doesn't matter where you go in life.........it's who you have beside you
Judy and DH Ray
Boomer & Petie Pie
F-350 Powerstroke Diesel, extended cab, long bed, Reese hitch, Prodigy Brake Controller.
34' Cedar Creek 34CKTS, 3 slides & a king bed
Keith M
Cle Elum
Posted: 06/05/09 09:21am Link  |  Print  |  Notify Moderator
If you are going to power an AC might as well do it right and get the Honda EU3000 or the Yamaha EF3000ise. If you want to save some money then drop down to the Yamaha 2400. I think the Honda 2000 will be working too hard and in the case of some a/c it wont work at all. Its not designed to run an ac. I wouldnt wasted money buying a cheap generator thats so noisy it defeats the purpose of going camping.
