Being that it is a rear wheel drive automatic, you cannot tow it 4 down without the usual modifications i.e. using an auxillary pump for the tranny or drivshaft disconnect. But it is a new vehicle so good luck in finding one for it.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
The IS is rear-wheel drive, so it shouldn't be towed on a dolly. Not a good idea to tow a car backwards. The question is whether you want to trust a $40,000 car to a lube-pump or driveshaft disconnect? The only approved flat towable Lexus is the IS 250 with the manual transmission. We considered an IS, but it is way too small, so we're going for a manual Maxima.
Peralko
USAF Retired
95 Country Coach Affinity
2006 Nissan Maxima
Peralko wrote: so we're going for a manual Maxima.
I don't think that is approved either. Just because it's a manual transmission doesn't make it towable. It depends on how the transmission is lubed.
Well, you're flat wrong on this one, Deen. The owner's manual clearly states a Maxima with a manual transmission is flat towable, as are other Nissans. BTW, the manuals are available on-line.
