RV.Net Open Roads Forum: Truck Campers: Happijac lubrication
 > Happijac lubrication
Page of 15
sirdrakejr
Las Vegas, Nevada
Posted: 06/18/09 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
If all that dis-assembly is just to lube the screw drive, why couldn't you put a hole near the bottom of the exterior tube and lube the gear just above the carrier so it carries the lubing up the screw? That way it wouldn't require dis-assembly each time? Would that NOT work?
Frank
KKELLER14K
BEAVERTON OREGON
Posted: 06/18/09 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I personally like to see the internals now that I have done this. It really does not take very long to do either. Zerking it is not a good idea because the internal tube moves inside the other for one...lube would only be able to get to a very limited part of the mechanism and you would have to pump in a huge amount, A big mess if you ask me...I lubed not just the entire worm gear but the bearing and square plate, where there is no way to get it in there unless you take it apart....sorry.
KKELLER14K
BEAVERTON OREGON
Posted: 06/18/09 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Forgot to mention that the outer tube does not have a coating inside. But if you need to paint it, now would be the time! Good luck with it you all!
oldwanderer
dunmore alberta canada
Posted: 06/18/09 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Great job on both the explanation and the pics, THANKS. Just printed off a hard copy of your report and will put it in my manuals binder just in case. I was wondering what type of lube hapijac recommends to use ? I can't tell from pics other than it appears to be a white grease but is it a extreme pressure type or synthetic or ?
Ken
2005 Dodge CTD
1996 bigfoot 30.1011
KKELLER14K
BEAVERTON OREGON
Posted: 06/18/09 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure of the lube type. I just used a little from where the top gears were.
serpa4
East Coast
Posted: 06/18/09 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
The worm is like 4 feet long. A zerk wouldn't get lube up and down the entire gear. Taking them apart really is pretty simple to do every couple years. I did over kill on the worm gear lube, put a ton on it.
Love the camping life. 06 Host Rainier SS, 07 Classic GMC Sierra 3500 DRW.
FarcticOx
NH or somewhere else
Posted: 06/21/09 08:24am Link  |  Quote  |  Print  |  Notify Moderator
KKELLER14K,
Thanks for a great post. My jacks are still working well but getting a little noisy and I was planning on investigating such a repair/relube this summer. You've made the task much easier.
Does anybody know if Happijac will sell replacement parts if they are needed?
FarcticOx
Run Silent, Run Deep
BLOG
2003 F350 Diesel DRW.
2005 Arctic Fox B1150 solar powered dry camper.
220 Watts Solar, 2 300AH 6 volt AGMs, Yamaha EF1000iS Generator
Tizi
Normandy Park, WA
Posted: 06/21/09 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Their website says 3 in 1 oil, and nothing about grease from what I read. Are they saying the original grease should last forever?
2008 Dodge Ram 2500 QC 4x4 - HEMI
2012 Arctic Fox 22GQ
Tizi's Transformer by Whazoo
bigfootford
Fair Oaks, California
Posted: 06/21/09 10:40am Link  |  Quote  |  Print  |  Notify Moderator
KKELLER14K, great writeup. About 6 years ago a fella did a write up and linked it to his website.....Dang if the Jack police didn't run him out of town!!!!!!
I've been servicing my jacks in the exact way you did for several years after reviewing and printing out the fellas write up.
Some guys use the blue, water resistant trailer bearing grease. I use the regular Lithium type.
The dis assembly process is a little different for the older non-drop down jacks..
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bigfootford
Posted: 06/21/09 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Apparently the MFG does think that the grease should last forever.....
My front jacks got noisy and started binding the 2nd year. Oh man was I PiXXed. I have serviced them twice....
Jim
Page of 15
