RV.Net Open Roads Forum: Tech Issues: Air Conditioner Noise
 > Air Conditioner Noise
Tech Issues Related Tips
Wheelman
Pleasanton Ca.
Good Sam RV Club
Posted: 07/03/09 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I was traveling down the highway with a/c on, all was normal. The a/c drive belt broke and of course the a/c quit working. I replaced the broken belt and now when the a/c clutch is engaged it makes a terrible screaming noise until you turn it off. Now the Check Engine Soon Light is also on. Any ideas on what is wrong with my 1994 Pinnacle with 454 Chevrolet engine P-30 chassis.
stevesandidge
kingsport tn
Posted: 07/03/09 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like the compressor bearings are shot. may be time for a new compressor.
steve
steve sandidge
RVIA certified rv tech
camping world rv university
class 54
fix-it rv service
USMC 1982-1994
91 holiday rambler imperial 37'
12th Man Fan
Flower Mound , Texas
Good Sam RV Club
Posted: 07/03/09 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
You are probably way ahead of me but if you have a serpentine belt check to make sure it is properly routed.
Happened to my son one time he miss routed the belt and it worked fine until the compressor kicked on and it would squeal.
Hope that is all it is good luck.
2009 GMC Duramax 4X4 DRW Crew
2005 31SKT Alumascape
Archieandchris
Maryville, Tn
Posted: 07/03/09 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
The reason your belt broke was probably due to the compressor seizing up and or binding. I would not engage the A/C compressor until you have it looked at by a tech. Or...you may have just a loose belt that is squealing like crazy and needs to be routed and or adjusted correctly....that may be the reason your check engine lite is coming on as well. You never know!!
Good Luck.
Happy Camping
Archieandchris
Amateur Radio Equipped AE4GN Extra Class
F250 6.0L PSD King Rancher 4x2 CC
Cougar 290EFS 31 ft./5'er (See Profile photo)
3.5/4.0 KW Champion Gen
1 Good Lookin' Wife 1 Pooch (Peek)
SSG 3/278th ACR TANG (Ret 22 Yrs)
M1 Abrams T/C
