RV.Net Open Roads Forum: Truck Campers: taking apart a Happijack
 > taking apart a Happijack
Truck Campers Related Tips
gsbuick65
Southaven Ms.
Posted: 07/11/09 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
isnt there a article on how to get this jack apart to grease the shaft? have one that isnt working as good as the other ones, and its newer
mike
2002 Lance 1130
2005 Dodge 2500 quad cab 4x4 CTD
Southaven Ms.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/11/09 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah there is. I dont remember where though. Maybe look in the Truck Camper University section?
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
wabbitman
Horsham, PA
Posted: 07/11/09 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I took the motor off the top and used a spray can of lithium grease and then exercised the jack.
wabbitman
Chevy Silverado 3500 HD ext cab 4x4
Vortec 6.0L V8 gasser
6 Speed HD Auto Trans
Z85 Handling/Trailering Package
HD Locking Differential
Bigfoot Truck Camper 25c10.4
Wife and Gary - Lab/Greyhound Mix
Days Camping in 2009 = 17
Americamper
Anniston AL
Good Sam RV Club
Posted: 07/11/09 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
There is a very detailed article on here somewhere with lots of pictures. I used it to disassemble mine and it was not that diffficult at all. You just need some circlip pliers and a little patience and grease.
2000 F250 Superduty 7.3 SB SRW, E rated Michelins, Torklifts, fastguns,2004 Northstar Laredo, 2005 Americamp 5'er, Triumph Tiger 1050, Yamaha YZ450
54suds
adk mts.
Posted: 07/11/09 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
heres one good site
05 Ram xcab drw 4x4 06 Bigfoot 25c10.6e
Troutguy
Brandon Twp. MI, USA
Posted: 07/11/09 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I just did all four of my jacks using this how-to by kkeller14k...
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22881036.cfm
It wasn't too bad of a job.
TG
* This post was edited 07/11/09 06:38pm by Troutguy *
2001 Red Chevy 2500HD X-Cab SB D-Max/Ally 4x4
2006 Arctic Fox 811S Truck Camper & Honda EU2000
2004 Clackacraft 15'LoPro Drift Boat
2004 Suzuki DR200 Dual-Sport motorcycle
2008 Suzuki DL650 V-Strom motorcycle
RV.Net....A B.F.F.
A.TCM.F.F. is Next
KKELLER14K
BEAVERTON OREGON
Posted: 07/12/09 04:11am Link  |  Quote  |  Print  |  Notify Moderator
Troutguy, how did that go?? Here is the link again...Not to hard to do...
Troutguy
Posted: 07/12/09 06:26am Link  |  Quote  |  Print  |  Notify Moderator
KKELLER14K,
It went great and I'd like to personally say Thanks for that post and all of the super photos that you provided and the effort that you put into it. The only thing that you either didn't mention or didn't show was a different removal procedure of the plastic push pin and motor gear release lever.
I discovered, after breaking the first push pin, that there are two small slots in the internal plastic elec. motor/disconnect mechanism that allow you to to insert a thin-bladed screwdriver to pop out the pin and lever versus prying them out from the outside of the jack tube...it works pretty slick.
Those small slots, I believe, are shown in one of your pics (8th pic down from the top of your original how-to post titled "Remove the lever and pin...") and they may appear to look like lube ports but I gotta believe the factory designed them to allow for removal of the pins.
I would post pics but I'm still not in to the 21st century regarding posting pics yet.......I have to try doing that.
Again thanks for the great thread on this as I'm still waiting for parts from HJ, (new gear set and push pin) I'll post about that experience when I get the parts......
TG
* This post was last edited 07/13/09 07:24am by Troutguy *   View edit history
54suds
adk mts.
Posted: 07/12/09 06:43am Link  |  Quote  |  Print  |  Notify Moderator
these bearings are not shown ,hj also uses cheaper acme screw assembly on lighter duty jacks.also there is another assembly at the lower end of the screw shaft that may bind under load?
ballscrew
happi screw assemblies
gsbuick65
Southaven Ms.
Posted: 07/12/09 09:46am Link  |  Quote  |  Print  |  Notify Moderator
ok, got the jack apart, mine didnt have a c-clip holding the manual gear on instead it had a solid pin. but the jack screw is dry. thats probably what the problem is?
