RV.Net Open Roads Forum: Excessive battery drain on 08 View? Help please....
 > Excessive battery drain on 08 View? Help please....
Class C Motorhomes Related Tips
pmv
New Hampshire
Posted: 07/14/09 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I have an '08 Winnie View. Just returned from a park with no hookups, but ran generator from time to time to charge batteries.
Went to sleep with FULL CHARGE. Only draws on house batteries were: propane fridge (starter) and night light and porch light--both on all night), and propane furnace (starter and fan) turned on at about midnight. FUrnace cycled about 6 times during night... Batteries dead by 5am (ish). Is this normal? seems like an awfully short lifespan for the batteries.
would appreciate your thoughts/help!
doghouse_owner
Seattle
Good Sam RV Club
Posted: 07/14/09 11:37am Link  |  Quote  |  Print  |  Notify Moderator
that is an extremely short time period. Suggest recharge your batteries, then check the battery water levels, refill as necessary, then replicate the situation and see if it happens again. Make sure the fridge wasn't accidentally left on 12vDC as that will definitely drain your battery down.
Wendy
Owned and trained by Cocoa, Mikey and the Ollie-man
2008 Roadtrek RS Adventurous
2009 Honda Sport Fit (ribbet )
Stowaway2 on swingaway tow frame
2002 Honda Odyssey EXL
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 07/14/09 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Batteries have been know to die rather quickly. The two lights probably draw an amp a piece, the fridge maybe and amp but the furnace could draw 15 amps. If you are near an auto supply store charge the battery and take it in for a check. Good luck
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
I am still wayne_tw
everywhere
Posted: 07/14/09 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Those two lights could have drawn 2 to 3 amps and you said on all night. You probably turned on other lights before bed, so you could have consumed 15 amp hours there alone. That furnance probably consumed 40 amp hours, and the refrigerator probably 1 amp hour. As you can see, you could have used a lot of the battery capacity. How do you know the battery was fully charged? If you used the built in gauge in the RV, they are well known for being inaccurate. You could have easily started with a 75% charge. When operating off battery, leaving any lights on, especially all night, can draw down a battery a surprising amount.
Krusty
Calgary, Alberta,Canada
Posted: 07/14/09 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
What type of batteries, and how many?
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
john1946
Venice FL
Posted: 07/14/09 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you still have the original batteries, they are pretty much worthless.
Most V/N owners have replaced them with Trojan deep cycle 6 volt batteries connected in series -- I have T105s.
John
2007 Winnebago View 23H
tatest
Oklahoma
Posted: 07/15/09 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
How many batteries, and how big?
Your load could very well do in a single Group 24 dual-purpose "RV-Marine" battery, overnight. The furnace will drain a small battery quickly, and just that porch light for 8 hours represents about 1/5 of a SRM-24's storage capacity, the fridge controller another 1/6 to 1/4.
On the other hand, if you have 200 AH of true deep cycle, 10 hour rating for 20 amp discharge, you should be good for all night, even with the furnace load.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
