51hogtied
New York
Good Sam RV Club
When I bought my TC the fridge would not cool properly. Come to find out the fiberglass insulation near the top of the fridge was not installed correctly and was blocking the flow of air up the vent. Corrected the problem and it worked fine. Good air flow around the coils is essential.
growler67
Boise, ID
I also did what Conch did. I have a cheapy orange solar panel battery charger thing that I put on the roof which plugs into small computer fan via 12v cigar lighter connection zip-tied below the fridge coils to push air up to the vent to help circulation when parked in direct sunlight. Good luck.
j.
2003DodgeRam2500STHemiQC4x4LB,Bagged-n-Ranchoed
2003NorthlandGrizzly990Cabover
1978AMFCrestliner15'Crusader85hp
2004SuzukiEigerAuto
Reddog1
El Dorado, CA
I put a computer fan at the bottom of the coils, blowing up. I had it in there for two days (100+ outside), and I could not tell any difference. I guess I will have to take a look at putting baffles in.
Wayne
Conch Cruiser
Southport, North Carolina
my fan is about half way up the back side of the frig. You could try moving it up from the bottom and see if that helps.
1999 Chevy 3500 SRW 4x4 Crew Cab Long Bed
Dunlop RVXT 265/75/16 W/Stock Steel Rims
1996 Coachmen Ranger 100SD
Tork Lift Front Tie Downs
Happijac Rear Tie Downs
Ride Rite Air Bags
Polar Cub AC Model 9201a-776 8,300BTU
Honda EU2000i generator
devildog1971
Rome
i left the thermostat on 3 everything in the reefer froze and busted one can was on its side and it broke the shelf yes my dometic gets cold and this stuff was not in the freezer
2005 Dodge 3500 CTD DRW crew cab 1997 Real Lite TC Rancho 9000 XL
Brad01
NC
Do you have the smae problem on propane as electric? this might help you isolate the problem. Good luck.
2005 Chev 2500 PU CC 4x4 SB Duramax/Allison with ARE Camper Top
2002 Keystone Hornet 32R TT w/ 1 slide
Wife: (Jane) Artsy person and Haiku Poet that loves to camp
Son: Junior at NCSU
RV Usage Pre-2006:unknown, 2006:60 nights, 2007:53 nights
Reddog1
El Dorado, CA
Conch Cruiser wrote: my fan is about half way up the back side of the frig. You could try moving it up from the bottom and see if that helps.
I read the information in the link you provided, rvmobile.com. In the fan paragraph one of the things it says is: "The important thing to remember is that the fan should be installed above the cooling unit, preferably right at the roof vent. The purpose of the fan is to improve the draft, not to blow air onto the cooling unit."
I find it interesting thinking back on the number of post I have read, stating people have put fans in the bottom, blowing across the coils, and they lowered the temp of their refer. I had no change doing that, and my experience is supported by RVMoble.
It also looks like I need to improve the venting. Mine is Bad Venting 1. I need it modify to Good Venting 1, probably using 1" foam insulation. My refer has from 2 to 3 inches clearance in the back.
Wayne
