kannegk
Stout, IA
First of all, let me say by saying that I have read many posts on here and have found some great information. This is my first post. I've read a lot of posts that are similar to mine, but need help so I wanted to give you all the details. Hopefully, someone will have some advice for me.
My wife and I bought a Passport 300BH this spring. I recently weighed the truck (2008 F-150 Super Crew 5.5' box) and trailer; here are the details. These are with the truck and trailer fully loaded, water tanks all empty.
Truck and Trailer - 12,460
Tongue Wgt without WD hitch - 880
Truck - 5740
Trailer - 6720
When we purchased the trailer, it had a Reese WD hitch. I have since converted it to a HP Dual Cam system to help with sway. We have 800# torsion bars. I love the sway control of the hitch, but we still have a LOT of bounce. The kids' butts bounce off the seat when we are going down the road!
I have tried any option I can think of to reduce the porpoising, but I have been unsuccessful. I have tried more tension on the bars, but that seems to take too much weight off the truck and contributes to more sway. I have tried less tension and the bounce gets worse. I've even tried pulling it with just a standard ball mount to see if moving the ball closer to the bumper would make a difference. Nothing seems to help. The 30-gallon fresh water tank is about halfway between hitch and axles and it seems to help very little when it is full.
I have been told that more tongue weight will help, but less tension on the torsion bars doesn't seem to make a difference. Even no torsion bars doesn't do the trick!
The porpoising is so bad that I am seriously considering ditching this unit and upgrading truck and trailer to a fifth wheel. Hopefully you all can point me in the right direction. Thanks in advance!
Kendall
edited 07/31/09 09:13am by kannegk *
Trail-Mate
Frederick, MD
Good Sam RV Club
First I would swap out the 800lb wd bars for 1000lb wd bars and see what you have. Also what is the milage on the Truck? Factory Shocks don't usually last very long. They may need replacing. Also Check Tire Pressures.
1993 GMC Suburban K2500 4X4, 454, 4:10 gears
Hensley Arrow
Jordan Ultima 2020 Controller
Montana Mountaineer Edition 32 PRD
Happy Camping !!
cachingcampers
Niagara Region,Ontario
1) undersized WDH bars- jump up to the next size bars
2) Porposing is usualy caused by UNLOADING the front axle.
Re size the bars & re adjust the hitch and make 100% sure you are achieveing front spring compression.
2010 KZ Spree 324BHS-LX- Equal-i-zer,Prodigy,Barker Hi-Power.
2003 Dodge Ram 2500 QC SLT Heavy Duty, 5.7L 4x4
1999 Ford Expediton 5.4 4x4 "Eddie Bauer"
Me-1970
DW-1967
DS-1995
Our Pics & Trips
Winter Camping Tips & Tricks!
eric james
Sioux Falls, South Dakota
I'm having the same issue with my 290BH and 800 bars. My porpoising isn't as extreme as you describe, more like bunny hopping on these terrible SD road.
I'm leaning toward 1000 bar swap. My tongue weight seems to be dialing in at 810.
edited 07/21/09 09:33pm by an administrator/moderator *
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
Wilburg
Massachusetts
I have 100 lbs bars and don't have the issues your talking about
2007 2500HD CHEVY 4X4 LT2- 6.6 D/A Intergrated trailer brakes
Dual Cam Reese
2001 21' Sweetwater pontoon boat
2007 Keystone Passport 280BH
2008 Polaris X2 500EFI ATV
kannegk
Stout, IA
Thanks for the quick replies!
The truck has 13,000 miles on it. I have swapped the original Goodyear 6-ply tires for new Cooper 10-ply tires. That helped with the sway issues quite a bit.
I am going to the dealership on Friday for a test drive with their hitch expert. I will mention the heavier torsion bars to them.
There is one thing I can't understand though. I took the time to level the trailer, measured the truck height at the four corners prior to loading, loaded the truck and then adjusted the torsion bar tension so the front and rear were both being loaded (front about 1/2" down and rear about 1" down). It still seemed to porpoise badly. Will the stiffer torsion bars help reduce porpoising that much?
ronj60
Sidney BC
I had a similar issue when I first got my setup, and it is very similar to your rig. Heavier bars would be advisable, and I would make sure you are getting weight distributed to the front wheels adequately (weigh the front wheels hitched to your rig and then unhitched at a weight station). Also, I installed Firestone air bags on the rear axle of the truck and that took the last little bit of bounce out of the F-150. Good luck, it CAN be done!
2007 Ford F-150/3.73 ratio/5.4L Triton
2008 Fleetwood Prowler 2702BS
Equal-i-zer Anti-Sway WD Hitch
Prodigy Brake Controller
Firestone Ride Rite Air Bags
Barker 3000 Tongue Jack
The Fisher Family
South Carolina, USA
Good Sam RV Club
I agree with all the above - I went from 800lbs bars to 1,000lbs - much better ride!
The Fisher Family
2009 Coachmen Captiva 281DSB, 2006 Expy w/Tow Pack, Reese WD and Dual Cam Sway Control
flguppie
Stuart
Good Sam RV Club
I'm considering adding a Roadmaster Active Suspension System.. A buddy of mine added it to his 250 for pulling his 5th wheel and it really helped. He even gets better gas mileage. Just something to consider....
FL-Guppie "small fish in a big pond"
2010 Trail-Lite TLX200rk Crossover Tail-Gator
1997 Dodge RAM 1500 5.9L
colliehauler
Mc Pherson KS USA
I would look at firming up your trucks rear suspension.
