RV.Net Open Roads Forum: Tech Issues: Liquid Roof Opinions
 > Liquid Roof Opinions
Tech Issues Related Tips
damac
usa
Posted: 07/26/09 02:40am Link  |  Quote  |  Print  |  Notify Moderator
Can you use this stuff on an older aluminum roof travel trailer?
faulkner1953
McKinney, Tx
Good Sam RV Club
Posted: 07/26/09 09:26am Link  |  Quote  |  Print  |  Notify Moderator
You sure can. Get it as clean as possible, then apply as thick as you can.
Regards,
Gary
2008 Ford F250 XLT Crew Cab short bed V10 gas
Pullrite Superglide hitch
2008 Laredo 265RL
Bill/Diana
Southeastern Pennsylvania
Posted: 07/26/09 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all of you for sharing information on this topic. I'm still undecided as to what action I'm going to take. The rubber roof is 13 years old but does not have leaks (knock on wood) nor any signs of cracking.
I called Dicor and spoke with a woman in tech support. I explained that I was thinking about coating the roof and looking for advice. She said the roof should last 20 to 25 yrs with proper cleaning. She said if my roof is not cracking or showing up with "alligator" cracks, then just leave it as it is. She said it is not necessary to coat it if there are no problems.
So still undecided at this time.
Bill & Diana
Please click here to visit our Website
MrWizard
Van Nuys, Ca
Posted: 07/26/09 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
yes, when i repaired the Alum roof on our previous MH
I washed it let dry, then scrubbed it with large scotch brite pad, wipe cleaned with a clean dry cloth, then put on the the Liquid Roof
it totaly sealed all the 'pin holes' in the alum
Connected via Verizon Via Motorola Droid with Android2 OS
sailingmyway
stuart fl
Posted: 07/26/09 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
near killed me looks bad works ok. starting to get small blisters that dont seem to effect the membrane. if i were to do it again ide not do it in fl sun try to have 2 helpers and scaffold the rig
john
John and Pat and a cat named BOO
Off to see America in our 93 Sport Coach DP and the little saturn tagging behind
Hope we can meet along the way
