rich racin
Pa
Good Sam RV Club
Looking for advise on how you handle a leveling jack repair/ replace. My HWH are direct acting piston type with touch pad control. My rear left jack will not retract and must be pried up. I did the damage myself at home being careless. I called HWH and they said you can order a new jack or send the old jack back for repair and they will repair. There is a 4-6 week back log. Just wondering what procedure is the best way. Order new and can you send the old jacket for the core charge. Help is appreciated.
Rich
Rich & Karen
1999 Coachman Santara
Malibu Tow'd
klm
SIOUX FALLS, SD
Good Sam RV Club
I am mechanically/technical challenged, but I am at a HWH certified repair center right now. My right front jack does not retract w/out the aid of my 2x4 pushing it up. I have new springs ordered, they arrived today as a matter of fact, and will be installed on Friday. I hope this resolves my problem, and a new jack is not necessary. Would it help you to take your coach to a HWH repair center? That info is on their website. Good luck, kathy
'02 KOUNTRY STAR DP
'04 PT CRUISER INFERNO RED
LUCKY THE TRAVELIN'BLACK CAT
Rich D.
New England
rich racin wrote: Looking for advise on how you handle a leveling jack repair/ replace. My HWH are direct acting piston type with touch pad control. My rear left jack will not retract and must be pried up. I did the damage myself at home being careless. I called HWH and they said you can order a new jack or send the old jack back for repair and they will repair. There is a 4-6 week back log. Just wondering what procedure is the best way. Order new and can you send the old jacket for the core charge. Help is appreciated.
Rich
Rich,
I had one that needed rebuilding, bought a new one and sent the old back for a core credit. That way I only had to get under there once. No problems since the swap. Check to see if they have any rebuilts in stock for the size you need.
Rich D. Wanderlodge LXi 43'
brobox
Sunny SW. Florida
Rich,
Check with heavy equipment repair shops in your area. Our MH jacks are not much different that rams used on heavy equipment.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
dougrainer
Carrolton, Texas
HWH has a backlog. So, either way (send in the old one or order new) will be the same amount of time. BUT, you will save money by having your old one rebuilt. It will be about 1/2 the cost to rebuild yours versus a new jack. Doug
CoachmenKen
Jackson, NJ, USA
How much does it take to bleed the fluid through the new jack?
Ken, Dawn, & Rebecca
Our Goldens, Penny & Tucker, waiting for us at Rainbow Bridge
Augie & Daisy - continuing as our camping companions
2001 Coachmen Santara, 3602 KS, F53 (purchased 7/04)
2009 Ford Escape XLT
States we have camped in
dadd45
northeast NEBR USA
Do a "search". This very topic has been discussed in the past with some very complete descriptions of what it took to change (and some good tips)...seemed they weren't that difficult......IMHO, of course
DadD45
2004 Cross Country Coachmen
2001 Wrangler behind
JUST HAVIN' FUN!!!
crouseman41
Blanchard ok
Good Sam RV Club
The bottom seal on the right rear HWH jack on our coach blew out about 3 months ago at the start of this trip. Found a hydraulic shop to rebuild it - cost was $137. It has worked fine since then.
Dale
Dale & paulette Crouse
rich racin
Pa
Good Sam RV Club
thanks for the reply's. There is a hydraulic shop local to me. I will check with them 1st. I need to study the procedure for the bleeding and install as well.
Rich
BarbaraOK
Livingston, Texas, USA
Rich,
Have you tried putting new springs on? We were having trouble with the jack coming up and new springs did the trick. Since the jack goes up with applying force on it, it appears that maybe it is the springs which normally supply the push up.
Barb
Barb & Dave - full-timing
Traveling catpanion Shadow (age 12)
Figment II (2002 Alpine 36 MDDS)
Mischief (2004 Subaru Forester Toad)
FMCA - F337834, SKP #90761
Our Blog
