RV.Net Open Roads Forum: Tech Issues: Front clearance lights dark
 > Front clearance lights dark
Tech Issues Related Tips
opastrains
Richmond, MI
Good Sam RV Club
Posted: 08/22/09 07:11am Link  |  Quote  |  Print  |  Notify Moderator
After front clearance lights stopped working, search revealed hot wire had worn through where it enters floor/wall of trailer. Hard time getting enough wire to reconnect with wire nut. Lights blinking upon return home last night, so needs further work.
Suggestions on how to get more wire loose from "inside" trailer wall so I can make a permanent splice? Wire is tight where it goes between floorboard and front wall of trailer.
Sargehut234
Cajun Country
Posted: 08/22/09 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Try adding wire insead of pulling it it is already tight.
Yaj
The Milky Way Galaxy (Hartford, WI)
Posted: 08/22/09 10:29am Link  |  Quote  |  Print  |  Notify Moderator
ditto!
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
2 dogs, 2 cats.
I wasn't thinking this far ahead!
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 08/22/09 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
Dr Quick
M'boro, Tn
Good Sam RV Club
Posted: 08/22/09 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
When I have tight conditions with wire I do this. Use heat shrink to cover splice, slip it on first. Strip wires back about 3/8 inch, then push ends of wire into each other. Solder wire and do heat shrink. That may do the trick.
Dr quick
dsigmon1
Conover NC
Posted: 08/22/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Is it loose enough inside the wall to pull it out?
You might have to disconnect the wire at the light & solder/tape on a new piece of wire & pull it from the bottom or floorboard to get you enough to splice it back in.
opastrains
Richmond, MI
Good Sam RV Club
Posted: 08/24/09 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Used Butt Splice on both wires - discovered both hot and ground had worn where the plastic cover contacted the wires. Heat shrink was part of the spice. Everything seems to be working 100% - had to modify the plastic cover to make room for the splices.
Thanks for all the good input!
