Tim-n-Deb
Lancaster, CA
Do you leave your e-brake on all the time or just when you need it?
What are the advantages/disadvantages to each mode? For the 500 or so miles I have driven my new rig, I like to turn it on only when I need it or for around town driving only.
Thanks,
Tim
2008 Fleetwood Expedition
FMCA #379187
wolfe10
Like you, I turn it on only when needed (or in stop and go traffic).
Leaving it on eliminates my favorite gear-- COASTING.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Sully2
Cincinnati
Good Sam RV Club
Mine is ON except when I get to wide open country
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
BIGDOMINO
Full Timing since July 13th 2007
Good Sam RV Club
I leave it on all the time. Helps to stop a big rig much better than relying only on the chassis brakes.
Steve__
Steve & Toni__
38 foot Monaco knight with every option available.
2001 Honda CRV in tow.
Wife running the show.
95 pound Golden named Max loving the ride.
FULL TIMING AS OF JULY 13, 2007
Yaj
The Milky Way Galaxy (Hartford, WI)
When I left mine on it drove me nuts, every time I let of the petal it would engage. I ended up wiring a small relay in it so it doesn't engage unless I tap the brake petal, then if I tap the accelerator it disengages. Works real good and I now leave it on all the time. Here is a link for a produced version of the system.
Exhaust Brake Switch
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
2 dogs, 2 cats.
I wasn't thinking this far ahead!
sailor_lou
Connecticut
Good Sam RV Club
I also turn it off when I don't need it. Maybe it's something I need to get use to, but I find it annoying that everytime I lift my foot up on the accelerator it applies the ex-brake.
Lou
05 Travel Supreme 38DS04
TMitchell
Punta Gorda, Fl.
Good Sam RV Club
I leave mine on fulltime. I just barely feather the trottle if I don't want the exhaust brake to engage, when I am slowing down.
The advantage of leaving them on is that the exhaust brake mechanism
will have less problems, as far as sticking, then if you just use them now and then.
The disadvantage is you may not use your service brakes enough to keep them in top shape. I have to purposely do some hard braking on my trips to keep the service brakes in good shape.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
Techie
Pahrump, NV, USA
I leave ours on all of the time.
2006 CC Allure 40' Quad Slides Tag Axle Cummins 400
2004 Honda Element EX/AWD Toad; Blue Ox Aventa II/USGear
MS S&P/EVDO
FMCA
Ivylog
Blairsville, Ga. USA
I'm with Brett on coasting and that is why I like the left foot switch on this DP to turn Jake Brake on. On previous DP I filed groves and added a rubber cabinet stop to the switch so I could turn it on and off without having to look to see if I had the correct switch.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Rob&Sue
Weston, Florida
Good Sam RV Club
Yaj wrote: When I left mine on it drove me nuts, every time I let of the petal it would engage. I ended up wiring a small relay in it so it doesn't engage unless I tap the brake petal, then if I tap the accelerator it disengages. Works real good and I now leave it on all the time. Here is a link for a produced version of the system.
I just had a BrakeSwitch installed at Custom RV in Red Bay/Vina, AL on my Spartan MM chassis and ABSOLUTELY LOVE it!!! The EB now stays ON ALL of the time and I get the benefit of coasting until the service brakes are tapped, engaging the EB. No more automatic activation of the EB when the master switch is turned ON. It should make for a lot safer driving and braking with no fumbling for the master switch when the EB is really needed in an emergency stop.
edited 08/29/09 01:44pm by Rob&Sue *
