RV.Net Open Roads Forum: 1990 454 TBI HEI will engine cranks but no gas for start
 > 1990 454 TBI HEI will engine cranks but no gas for start
JeepBus
Vancouver, BC
Posted: 09/16/09 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
semiretiredDIY wrote:
My 454 is a 95, understanding that, I checked part # for the fuel pressure regulator, they are the same for the 90/95 maybe you could explain?
I definitely don't have all the answers but a quick search turned this up: http://www.diy-efi.org/gmecm/faq/tbi_fp.html
Apparently there are different GM TBI regulators and P/N 17113079 is the regulator for a 7.4L motor that needs 26-32psig.
I couldn't find P/N 17113079 in GM parts direct etc but it did cross to another number here so it looks legit.
http://www.rmsautoparts.com/proddetail.php?prod=217-391
2004 Discovery 39L
Argosy24
MI
Posted: 09/16/09 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I did check the fuel pressure, compression before I tore the engine in the pictures down. Fuel pressure was 13 psi.
I don't know what you looked up for the regulator but if it was a rebuild kit that might not mean a lot. All they are is some gaskets and the diaphragm, the pressure is set by the spring, the rebuild parts could be common. As a matter of fact most kits I've seen have more parts you don't use than are used.
semiretiredDIY
WA state
Posted: 09/16/09 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks JB, I will be sure and order the reg for 26/32 psi, if and when I need one.......LG
Gale Hawkins
Murray, KY
Posted: 09/17/09 12:48am Link  |  Quote  |  Print  |  Notify Moderator
They could have beefed up the fuel pump getting read for the MPFI system that became standard in about 1996?
JeepBus
Vancouver, BC
Posted: 09/17/09 01:06am Link  |  Quote  |  Print  |  Notify Moderator
I think it's more likely they upped the fuel pressure in an attempt to boost the HP rating. I think they were trying to compete with the Dodge V10 that was introduced in 1994. Just my guess.
john2005
Florida state wide
Posted: 11/12/09 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ignition Control Module was the cause of no gas to run issue - purchased a new one at Autoznone and she started right up runs like a top. Thanks for the advice everyone and all.
john2005
Florida state wide
Posted: 11/12/09 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
mike brez
milford ct
Posted: 11/12/09 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update. I will keep that as a reminder for my own 454
1994 Pace Arrow 33L Class A 454 P30 2002 F250 lariet crewcab 4x4 7.3 PSD srw short bed auto 3.73 gears,reese 16k slide hitch,reese brake controller ford factory aic,autometer three guage pod trany temp,pyrometer,turbo boost,banks 4inch monster exhaust,aFe air box,sonnax valve and tri springs,magnafine trans filter,Wicked Wheel,TS flip chip 75/100/125/OMG,03 tt heated/signal mirrors,runningboard leds.Other than that its all stock
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
