RV.Net Open Roads Forum: Tech Issues: slide seal problem
 > slide seal problem
Tech Issues Related Tips
mdennis
Lakeland,FL
Posted: 09/06/09 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 08 freedom lite 279tb....it is on a keystone 280bh chassis with extras. My problem is that the slide seal does not always want to come out. I have to get on a ladder everytime I extend the slide to pull some of the seal out. This is a real pain. I learned that I had to do this after I started having a slide leak. Anyone now how to keep me from crawling up there?? I use seal lubricant and one shop already told me the slide cannot be adjusted and could not figure out the problem. Now I am at a larger shop.
Matt D.
Lakeland,FL
2008 Keystone Freedom Lite 279TB
2005 Ford F150 Supercrew
Reese Weight Distributing Hitch
Reese Dual Cam Sway Control
fordsooperdooty
Orange Kounty Kalifornia
Posted: 09/06/09 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
If the seal just fails to pop out when the slide is deployed, yet it doesn't show any signs of leaking....As a wise man once said (actually, he said this all the time!)...What...me worry?
You can spray a bit of 303 Aerospace up there to kind of slick things up..not WD-40!
A Jayco is not just an RV, it's a way of life!
mdennis
Lakeland,FL
Posted: 09/06/09 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
THE SEAL FAILS TO DEPLOY AND IT LEAKS...THATS WHY I CLIMB ON THE ROOF AND PULL THE SEAL OUT..
fpresto
Maryland
Posted: 09/06/09 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect that you are talking about the wiper not the seal. The wiper is to get moisture and debris off of the slide when you retract. The actual seal is inside and doesn't "flip". I think at times they all hang up and don't flip. When mine does it I use the awning rod to flip it out if I get tired of looking at it.
If you are getting a leak then you have more serious issues than a wiper flip problem.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
Cool Canuck
Winnipeg, MB, Canada
Good Sam RV Club
Posted: 09/06/09 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what you mean that the seal does not come out. Most of the seals, seal against the slide when fully closed or fully open. They have a wiper seal which, as the name indicates, wipes some of the moister off the slide on the way in. If your seal is not staying attached to the main coach, it needs replacing. What happens, over time the metal spline rusts out and won't stay in place. If the wiper is just staying tucked under that shouldn't cause a water leak.
04 Everest 343L
01 F250 PSD S/C S/B
jliveit
ohio
Good Sam RV Club
Posted: 09/06/09 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem from day one with my Heartland and all 3 slides if they are not flipped out it will leak. Have just got in the habit when the slide is allmost out I run my hand along the top from the inside and flip them out. Have noticed if after the slides have been extended for a while (days) they will flip out by themself but after they sit closed I have to flip them out by hand.
Some may call it a wipe but it is a seal as it is the only thing on the bottom of the slides to ack as a seal, nothing on the floor seals up against anything except for the rubber wipe as some people call it. If the bubber seal on the sides or top are not flipped out any water will run down to the bottom rubber seal and let water run in on the floor.
dry_fly
Northern Arkansas
Posted: 09/06/09 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I, too, have the same problem with two of our slides, and have to run something down while opening to turn them out. It does seem to stop the leaking.
forty4san
Full Time, Some Place
Posted: 09/06/09 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
It was suggested to me to put anti-skid tape along the edge near the seal so that when it came out it would make it come out so that you would not have to manually bring it out.
Susan I
2008 McKenzie Starwood 32 FKD TT
Hensley & Prodigy Brake Controller
03 Dodge 3500 Quad HO Diesel DRW 4:10
Fulltiming, On the road somewhere.
jliveit
ohio
Good Sam RV Club
Posted: 09/06/09 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Have thought of doing something like forty4san has in mind but had not thought of the anti-skid tape, should work as long it does not tear up the seal. Read some where on here of someone just running a bead of silicone along the top of the slide to make it flip out, just have not tried it yet.
