kaydeejay
SE Michigan, USA
mikesar wrote: I hate to be argumentative but I did try it. On the way camping this weekend. the battery wasn't even hooked up. I got on level ground let truck roll in neutral applied brakes manually it stopped the tow vehicle and camper so the trailer brakes were working without battery Your brakes will work fine under normal conditions BUT THEY WILL NOT WORK IF YOUR TRAILER BREAKS AWAY FROM THE TOW VEHICLE!
Think about it. If the trailer is disconnected, where will the brakes get power from?
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
Dennis M M
Geneva, IL
Good Sam RV Club
It varies with the mfg. None of the 12 volt systems in our Newmar will work without a battery in place.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
kaydeejay
SE Michigan, USA
mikesar wrote: I did not know the law required an emergency brake away. I had a popup that had brakes but it did not have brake away system. Is it a weight thing or what I believe most States require Trailer brakes, with a breakaway switch, for trailers over 3000#.
alfa38user
Fl
The battery acts as a sort of filter and a load for the output of the converter, (depending on the design of the converter). I would always have at least one in place. You could end up damaging some of the 12V stuff without it in place. Yes, it may work for a while (apart from the emergency brakes!!) but it may also shorten the life of some of your 12V components.
Alfa38User
Montréal, Canada
Alfa Gold 38 (253 RLTES - 2000)
(SW Florida)
jdog
Some Place
Dennis M M wrote: It varies with the mfg. None of the 12 volt systems in our Newmar will work without a battery in place.
BINGO!!!!!!!!!!!!!!!!
ChainReaction
Maine
RV's are designed to operate off the battery with the converter acting primarily as a battery charger. Without a battery, the converter cannot supply enough amperage to run your furnace, refr, lights, etc. at the same time. We get many calls in the fall from folks that are having strange issues with their appliances. Usually a furnace short cycling or refr. mysteriously showing a check light(subsequently resets just fine!). Both are usually the result of a weak or dead battery and the converter not being able to keep up. A healthy battery and converter together can supply all the power your RV can ever need..
Maintcpo
Central California
Yes, with a battery connected from the Truck you will have power. BUT THE WHOLE PURPOSE OF THE EMERGENCY BRAKE AWAY is to stop the trailer in the event of a separation from the Tow Vehicle. Now you have a run away trailer with no way to stop it! That is reason for battery on the TT.
Dan, Ret Navy CPO
Minnie The Wife Extraordinare
Chris Our Son the Genius
3 Dogs 1 Dumb , 1 Fat and Stubborn, and 1 new and Adorable
2005 Jazz 2550RL 5er
2003 Dodge Quad Cab Long Bed Cummins 6 shooter
mikesar
North Central Arkansas
well I will say it has been very educational. I think the verdict is in "thou shall have battery on TT". although opinions have varied I can see the need for the battery. I thank you all for all your input mike
Anything worth doing is worth doing right
