Need some advise on installing a 30 amp outlet for my camper. The outlet will be about 40feet from the service box and I will have to also use a 25' 30 amp extension cord to reach my 25' camper cord. My plan is to use 8 gauge wire from the service box to the 30 amp RV outlet box. Is Romex available in 8/2 with ground? Or will I have to go with single strand wire in conduit?
2000 Fleetwood Terry, Model 275J EX
2003 Ford F250,V10,6.8L, Super Duty, 4WD, Quad Cab
16K Reese Hitch w/slider
RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
First, are you going to buried it? If so put in 1/2 conduit and use 3 #10 THW stranded wire which will be alot easier to handle. Also MHO only use single pole 30 amp GFI. MO2CENTS CharWan
Can't help you with yer question. However, why stop with 30 amp service since you're using so much extension? When we built our RV driveway and installed our water and electric hookups, the cost difference between a 100' buried 30 & 50 amp service line was neglegable. More than once we've been glad we had 50 amp service installed for our camper here at the house.
