RV.Net Open Roads Forum: Tech Issues: Water Heater Won't Ignite
 > Water Heater Won't Ignite
Tech Issues Related Tips
C Schomer
Buckeye, Az.
Posted: 09/20/09 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Mine old WH had problems staying lit for several outings. I kept taking the spark rod out to clean it and that would keep it working til the next trip. The porcelain insulator had a dark mark that wouldn't clean off - carbon tracking. I tried cleaning all the connections and even added a large ground wire from the module to the rod and nothing worked long term til I replaced the rod. Atwood $35, ebay $5 delivered. Cleaning the ground connections is also important cuz the module gets a 1/2 wave rectified signal thru the flame that is measured in microamps - yeh, millionths of an amp. Mine works flawlessly again. Craig
03Dodge QC HO CTD Dually NV5600 4.10 Rear/WD A2K turbo Diablo Predator Quad BF 4" exh PRXB Pacbrake Rancho 9000s FS Airbags Onboard air/in-cab controls HUGE custom intake Custom hauler bed. 98 Sunnybrook 30RLFS 5er.WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
Hamops
Oshawa, ON, CA
Good Sam RV Club
Posted: 09/21/09 10:20am Link  |  Quote  |  Print  |  Notify Moderator
TMBLSN wrote:
"BUKSHEE"
Is that a brand name?
Ain't no brand! That's a word my granddaddy used when something wasn't a workin'.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2006 Cruiser CF30SK 5vr, fully loaded.
Reese 16K Slider & Bedsaver,a Prodigy Controller and Rearview Camera System
tcman
Aldergrove, BC
Posted: 09/21/09 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
The Atwood water heater circuits are sealed in a block of black epoxy. What you are describing is also a sympton of a bad board. It happened to mine. I borrowed one off my neighbor to prove it was the issue. I swapped it out and all was fine.
2006 SnowBird 9'6
2005 Chev SRW
