2EZ2 RUN
NW FL
I cut a 8" length of 4" Eternabond and pealed the protective cover halfway back along the length:
http://members.cox.net/andy-williams/tape&tools.JPG
Andy
New 2 RVing
1994 30' Cobra Passport on E350 chassis
2EZ2 RUN
NW FL
I need lessons!
fold back:
first attach:
http://members.cox.net/andy-williams/half%20on&fold.JPG
final fold:
final cover:
JAXFL
Jacksonville, Florida, USA
So far so good. We had a leak in the patio room roof and no mater what I tried the darn thing still leaked depending on the way the rain cames down. About a month ago I used the tape down the seam in the roof that was leaking and NO MORE LEAK. I also developed a small pin hole in the awning and haf put a small cover over that so should be good for the next 10 years. Just google and you will find it, I don't remember the name of the compay I got my 50'x4" roll from but they were a roofing company supply house.
pianotuna
Regina, SK, Canada
Good Sam RV Club
Hi all,
The only downside I know to eternabond is that the edge of the tape is sticky--dust and dirt will stick to that.
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
map40
MI
pianotuna wrote: Hi all,
Yeap, but if it bothers you, you can put a small bead of sealer, and it is done.
2007 Four Winds 31F
Life rocks when your home rolls
pianotuna
Regina, SK, Canada
Good Sam RV Club
Hi map40,
What type of sealer? My old RV was almost more eternabond than siding LOL! It did look ok initially--but then got very shabby from the dirt accumulation.
map40 wrote: pianotuna wrote: Hi all,
map40
MI
pianotuna wrote: Hi map40,
Regular Dicor lap sealant, not self-leveling. Just small enough to cover the sticky part.
gitpicker2009
texas
On that dicor self leveling lap sealant, do you scrape off the old before applying the new?
thanks,
anthony
map40
MI
gitpicker2009 wrote: On that dicor self leveling lap sealant, do you scrape off the old before applying the new?
thanks,
anthony
They recomend that you do, but I never did. I just cleaned it really good.
gitpicker2009
texas
I had an RV tech tell me to clean it with "mineral spirits", but then I read that it would cause problems because of the petroleum. Something about not sticking as well.
What did you clean it with?
anthony
