mtnman1989
Collettsville, NC
How tall is my motorhome?
I have a 1994 Fleetwood Coronado 30 foot long with one AC.
I was wondering what height or clearance I need to be aware of?
Thanks,
mtnman
dbbls
Missouri
Good Sam RV Club
Get yourself a tape measure and check it. That would be better than any of us guessing at it.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Argosy24
MI
Measuring is the only way to be accurate. Everything from tire height to suspension condition to weight will affect your height.
Hjudge49
St. Augustine, Fl.
And you really need to know. I recently had the antenna hit some low overpasses up North. Very scary.
RCtime
Rancho Palos Verdes, Ca.
Good Sam RV Club
Here is how I did mine. Got on the roof and measured the unmovable high spots, like the AC unit. then the movable high sopts like antennas.
Then measured the roof line to ground and added the totals.
Make sure your rig is up to ride height if your a diesel.
Ron
2002 34HD Winnebago Journey DL, Cat. 330
2004 Honda CRV - Garmin 2610
Great wife & Cavalier King Charles Spaniel
TT/N
petiredpete
garaged in havasu
take a straight board, piece of pipe and tape a level to it, or use a 4 ft. level...place on highest part of m/h, hold level and measure to ground....write down the measurement on a piece of clear tape and place at top of your windshield for justin... JUSTIN CASE????
Norm Payne
Livingston, TX
Good Sam RV Club
After you measure it convert to meters and post that in you motorhome too. In case you go to Canada you will need that.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
jimhaz2402
Crossville, TN USA
Good Sam RV Club
I aimed a laser level from our highest point (top of satellite dome) to the wall in our garage---and measured from there. It was exactly what the manufacturer said it should be, but I, like others, recommend you measure your own coach to be real sure.
edited 09/20/09 10:59am by jimhaz2402 *
Nomadac
Columbus, IN
How high is high?
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
Car Dolly w/1996 Toyota RAV4 2WD
1963 Pontiac Grand Prix
jauguston
Bellingham, WA
High is two inches more than the bridge (-:
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
AIMS 2500w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
