RV.Net Open Roads Forum: Travel Trailers: 2006 wilderness yukon, axle problems
 > 2006 wilderness yukon, axle problems
Travel Trailers Related Tips
burnsbunch2
michigan
Good Sam RV Club
Posted: 09/23/09 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
We are into our 2nd rear axle replacement with our 2006 Wilderness Yukon 27 ft TT, with slide. In both situations, the left rear, drivers side tire on the inside, have worn excessively. The first axle replaced August, 2008, Dexter axle. Dealer claimed it was possibly a defective axle shaft. The most recent, this month sept, same problem. Dealer in process of replacing again. Trailer is definately not overloaded, no major pothole shots, even if so, the front axle would of shown some type of problem. In any case, not twice in 2 years.Fortunately costs to replace have been minimal due to extended warranty ins.However this should'nt be an ongoing problem.One thought has been in the backing the unit into my driveway, possibly the angle, however I've got ample room for backing, approx 2-1/2 cars wide. Has any one experienced this type of reoccurring problem? Any suggestions are truly welcomed
heavyputer
Ontario, Canada
Posted: 09/23/09 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like an axle alignment problem to me........
If at first you don't succeed, skydiving is not for you!!!
Heavyputer, 1 DW,
2008 F150 4X4, 5.4l, 24 valve
2008 Dutch Star, 400 Cummins, 6 Sp Allison
Krusty
Calgary, Alberta,Canada
Posted: 09/23/09 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Find a good alignment shop that will work on trailers
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
JJBrown
Whitby, Ontario, Canada
Posted: 09/23/09 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I know backing my unit into my driveway the axles look extremely flexed.....not sure how strong they are? A lot of the flex could be in the rims? I would have the alignment checked out.
Billyj571
Marysville,WA
Posted: 10/07/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
alignment problem like krusty said .
