RV.Net Open Roads Forum: Fifth-Wheels: prodigy maxed out and won't stop 5er
 > prodigy maxed out and won't stop 5er
Fifth-Wheels Related Tips
pcm1959
St Augustine, FL
Posted: 09/29/09 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
"Just had the bearings done on my Outback" Done being the keyword here. IF the brakes worked fine prior to you having the bearing done, I can't imagine why they are not working well now.
If you do not know for sure that they pulled each wheel and hand packed the bearings, it's a good possibly that they just pumped them full of grease via the e-z lubes. IF that is not done correctly - a warm hub, warm grease, and lifting each wheel spinning it slowly while pumping the grease - it will blow out the rear grease seal and cover the breaks with grease.
Here is my previous experience and post on the subject:
I will never use the Dexter E-Z Lube feature on my trailer. Just last weekend, we decided to remove the drums and do a visual of the brakes and bearings. On the left rear axle and right front axle, the seal was blown. The brakes were covered in grease. I never used the fittings so it must have been done prior to delivery either at the factory or by the dealer.
SO now, the fiver has all new brakes. BTW, the bearings all looked perfect. And mind you, this fiver has less than 7k miles on it.
So it's visual and hands-on checks for me as I do not want to risk blowing those seals and ruining the brakes. Good luck. pcm
smkettner
Good Sam RV Club
Posted: 09/29/09 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
They did something wrong. Have them fix it if you trust them. I would be inclined to take it to a different shop. Although I tend do this work myself to avoid such nonsense.
pcm1959
St Augustine, FL
Posted: 09/29/09 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
X2! pcm
BruceStarkey
Ontario, Canada
Good Sam RV Club
Posted: 09/29/09 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps the rest of you can chime in on voltage readout settings as well.
Two observations: Prodigy will indicate faulty grounds or shorted magnet wires with a code.
Previous setting of 9.8 even sounds high for an Outback trailer but I'm only familiar with our previous 36 RLTS Cedar Creek Custom that had magnet brakes and was closer to that weight than our current trailer that has hydraulic disc brakes. That Cedar Creek seldom went over 7 volts being stopped by our old Duramax and this trailer although weighing around 17,800lbs soaking wet also never reads over the 7 volt readout under normal braking events
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
CardMan
Saugerties, NY
Posted: 09/29/09 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a prodigy and had same problem. Answer was grease on the magnet/ drum surface. Grease on pad will usually cause brakes to lock up. My inner seals went bad and dropped grease on the magnet face. When applying the brakes fully with the manual slide bar the trailer wouldn't even hold my truck back at an idle. We had to remove all drums and clean the magnets/drums.
It could be a bad wire but my guess is a greasy magnet...
Good Luck!
Sean
2006 Ram 3500 Quad Cab 5.9L HO CTD 4X4, Auto, DPP Cool Hose, Muffler MIA , Reese 15k slider, Prodigy,... more to come!
2004 Cardinal 31LX 2 slides
GCW: 19,600lbs
5er: 11,600lbs (2,300lb pin)
dsigmon1
Conover NC
Posted: 09/29/09 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
You haven't bumped your Prodigy with your foot or knee & gotten it off level?
I did that one time. It about drove me crazy. It was not moved that far but sure made a difference in stopping power.
Vulcaneer
Northern New England
Posted: 09/29/09 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
The Prodigy will give you a signal if it is not within the correct angle. ex: if pointed upward, it will show _ _ at the bottom of the readout. This is shown in the instruction pamphlet.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
2003f350
Coventry, RI 02816
Good Sam RV Club
Posted: 09/29/09 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
You said that the brakes were fine when you brought it for the bearing repack??
Obviously they did something wrong, grease on the linings does sound like the problem, or else they really messed something else up.
By all means go back and complain unless you have someone else you trust to check it out.
Ed & Shirley.
Truck, 03 F-350, 7.3 PSD, 4x2 Supercab, Lariat, Long bed, Toreador Red and Arizona Beige., Rhino liner, Reese 16k hitch, Prodigy Brake Controller, Custom-Flow Tailgate, C-Betr Mirrors.
Camper-02 Thor Citation 5th. wheel, model 295P
