RV.Net Open Roads Forum: Class A Motorhomes: Best Portable Heater for MH
 > Best Portable Heater for MH
BIGDOMINO
Full Timing since July 13th 2007
Good Sam RV Club
Posted: 10/02/09 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to buy another electric heater to use. Had one for some time but it kept tripping circuit breaker.
I know I need to manage what I sue at the same time.
What units are you all using? Want to use it in colder weather. We are full timers and use the rig in the winter (Texas).
Thanks.
Steve__
Steve & Toni__
38 foot Monaco knight with every option available.
2001 Honda CRV in tow.
Wife running the show.
95 pound Golden named Max loving the ride.
FULL TIMING AS OF JULY 13, 2007
pianotuna
Regina, SK, Canada
Good Sam RV Club
Posted: 10/02/09 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hi BIGDOMINO,
I'd go for any non fan radiant type heater. Since there appears to be a problem with breakers shutting down I'd aim for 1000 watts or less.
Some of the oil filled units have two switches so 600 watts or 900 watts or, with both switches on, 1500 watt settings are possible.
I picked up a nifty little 466 watt oil filled unit for the bedroom in my RV. (labeled 600 watts but the labels are often wrong).
I'd also recommend buying and using a kill-o-watt meter--it can be most useful for finding out what the *real* numbers are on all 110 volt electrical devices.
Thanks.
Steve__
* This post was edited 10/02/09 03:35pm by pianotuna *
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
skipnchar
Topeka Kansas USA
Posted: 10/02/09 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
ALL 120 volt electric heaters are limited to 1500 watts of power so differences are mostly a matter of convenience or personal preferences. Remember that if you're using an electric to heat the interior AND your furnace is the source of your heated plumbing, your plumbing is not being protected from cold weather. If you have electrically heated plumbing then you're just adding even LARGER loads on your electrical service. Good luck / Skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
BobMary8101
Lake Co, FL
Good Sam RV Club
Posted: 10/02/09 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
We use an oil filled electric that looks like a radiator and it does quite well. We set it in the front room. We have dual furnaces, the one in the bedroom also heats the basement, we set it to come on if the temp in the bedroom gets to 50 and it keeps the tanks etc. safe.
Bob
Bob and Mary
Isabelle, mini-daschund
Pace-Arrow Vision 36B
1999 Ford V-10 w/Banks Power Pack
Toad: 2008 Ford Focus
FMCA F398511
Anml_341
Ontario
You might consider a Big Buddy heater from Mr.Heater. uses 4 D Cell batteries to run the fan if you really neat a fan. Most people do not. Propane heat, great. Various size available up to 18,000 btu. Down side can be some additional moisture (condensation on windows) in your unit. You can also get an electrical adapter to plug into the wall househould current. Good inside and outside-portable.
Frank Spence
Ontario Canada
Member: Explorer-RV Club (Canada)
Member: FMCA #F275853
We invite you to check out our websites:
A) General happenings in our lives
B) Articles & book written and published:
Email:frankspence@hughes.net
BobMary8101
Lake Co, FL
Good Sam RV Club
Posted: 10/02/09 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Bob
PS: It came from Wal-Mart
garry1p
Oklahoma
Good Sam RV Club
Posted: 10/02/09 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
We use 2 of the small cube heaters both set on low (750W) one in the rear and one up front. Never popped a breaker. However; when using the microwave we would turn off the front heater.
Lowest we have camped is 18 deg at night but always got to 30 or above in the daytime.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
LEN Retired
SW Michigan ( Two Paws )
Good Sam RV Club
Posted: 10/02/09 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'm presently using the EdenPure in my 5er in northern lower Mi. I used it all last winter at home in my living room which has a high ceiling. It has made the interior of the 5er comfy and the onboard heater does not come on. Bill
06 GMC 2500HD Duramax, 2007 Holiday Rambler Alumascape Suite 32SKT,3 slide 5th wheel " SEMPER FIDELIS "
Dick_B
Palos Heights, IL USA
Good Sam RV Club
Posted: 10/02/09 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
We use one from West Marine (www.westmarine.com). They have a portable heater with fan and thermostat for $64.
Of course, you could always see what Wal*Mart has!
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
garym114
Posted: 10/02/09 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Picked up a DeLonghi at Lowes, clearance for $20. Remote with two heat levels, thermostat and it rotates.
Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
