RV.Net Open Roads Forum: Hot water flow dropped by at least 1/2 - ?????
 > Hot water flow dropped by at least 1/2 - ?????
jerseyjim
New Jersey
Good Sam RV Club
Posted: 10/12/09 05:24am Link  |  Quote  |  Print  |  Notify Moderator
I get that all the time. For instance, turn on the shower hot water...all is well until the water gets hot. Then...the pressure really drops. Why? Don't know. But all I do is turn the knob...and the (hot) water pressure comes right back...then adjust it (for comfort) with the cold.
No problem.
lfeather
Titusville, FL
Posted: 10/12/09 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Don't ask me why, but if the outside shower faucet is on with the outside shower head valve off, it can cause this problem. Make sure the outside FAUCET is off.
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Toad
SMI Air Force One toad brake
brobox
Sunny SW. Florida
Posted: 10/12/09 08:32am Link  |  Quote  |  Print  |  Notify Moderator
When my HW flow did the same thing, it was the check valve at the rear of the hot water tanks that had stuck almost shut. You can remove the valve as a temp. fix.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
lwasouth
Good Sam RV Club
Posted: 10/12/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I also have a Winnabago Adventurer and have had the same problem. One time no hot water and another time very low flow. The problem is the check valve Winnabago installs on the back of the hot water tank. This check valve is brass, but the inside is plastic and can fail in a closed or partially closed position. You will need a 1" box end wrench to remove and reinstall the valve. Use extreme care removing the plastic plumbing fittings or they will leak when reinstalled
Pirate
Fall Branch, TN
Posted: 10/12/09 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto. Same thing with me. Reduced hot water. I replaced both valves.
97 Itasca Suncruiser F-53
2006 Vantage Mobility Dodge Grand Caravan
BWhite
Metrowest,Ma
Good Sam RV Club
Posted: 10/12/09 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
I had to replace the mixing valve on my Atwood hw heater .
Bill and Patti
Gizmo a Black face Tri-color Pembroke Welsh Corgi
Laci a Red and White PWC
06 Fleetwood Revolution LE 40E
05 Hyundai Elantra Toad
Member, Revolution Owners Group,FMCA,CAT RV Engine Owners Club
www.revolutionmotorhome@yahoogroups.com
