RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
A flea bomb works for fleas, check with your local hardware store for something that will kill the insects that you want to kill. Each can is rated for so many square feet, say 450 square feet. That is plenty for your RV.
Make sure there are no pilot lights on, and the refrigerator and hot water heaters are off, or set for electric only. Turning off the propane tank, just to be safe. You might want to shut off all the 12 volts (if you have a disconnect switch) so the propane and carbon monoxide leak detectors are not running.
Then put out some newspaper, and set off the can as directed in the instructions, leave the area, and come back 4 - 8 hours later. Let the windows stay open a while, to air it out.
If you can do it in your house I would not see what the difference is for doing it in your RV. Just follow the instructions you should be fine unless it says do not use in RV.
2010 Passport UL 290BH
2006 Ford Expedition Limited
i use the one from raid, that smokes and is non-flameable. comes in 3 packs, 2 for the house, 1 for the camper. what's nice is it more a smoke, not a mist so there's no wet residue.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
