njtony
indiana
Has anyone removed the heat shield aroung and used ceramic plug wires. the shields are a real pain to get off, any problems leaving them off?
pulsar
Lewisville, NC
Good Sam RV Club
Moved from Forum Technical Support to Tech Issues.
CNC.R.V.er
Lincoln Park,Michigan
We have the Jacob's plug wires on our M.H. and it still cooked wire on right rear.Fixed it by covering whole wire with heat resistant tubing.So far so good.
Chris & Linda
1989 Pace Arrow 34ft.
Bill/Diana
Southeastern Pennsylvania
I too use the Jacob's ceramic boot plug wires. Have used them on the MH 454 Chevy engine for the past 30,000 miles with no problem. In fact, I just replaced all the plugs, ditributor cap & rotor...the plug wires looked to be in great shape.
Bill & Diana
Please click here to visit our Website
Jim83Itasca
La Quinta Calif
I use the "Heat shields" with plain old "Borg Warner select" straight boots from Pep Boys and for years along with 15,000+ miles they still are in good shape......
Jim
MI Director
Michigan
Good Sam RV Club
Have Champion lifetime ceramic wire set on for over five year now and still no signs of any heat damage.
njtony
indiana
thanks to all
MrWizard
Van Nuys, Ca
I agree the shields are a pain, i put new wires on in the spring and swapped all the heat shields from the old wires to the new wires, also put in a new dist cap & rotor, i have new ignition & brain module on my shopping list
Connected via Verizon Via Motorola Droid with Android2 OS
BenK
SF BayArea
Mine don't come off when changing the plugs and they don't get in the way.
Maybe just my GMT400 era 7.4L. I like Taylor spiral wound 'wire'
I used to and probably continue to check out new types of plugs, but
have always gone back to copper (non platinum) plugs and cut back the
ground electrode. Same or similar to indexing plugs, but no reduction
in CC volume
-Ben Picture of my rig
