RV.Net Open Roads Forum: Fifth-Wheels: Leveling 2 Axle Fifth Wheel?
 > Leveling 2 Axle Fifth Wheel?
Fifth-Wheels Related Tips
New Vision
Iowa
Posted: 10/14/09 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I use 2X8 and 1X6 planks for the wheels. For the jacks I use 4X8 blocks made from post we used when we built our deck at home.
I O W A !!! G O H A W K S !!!
2002 KZ New Vision 2457 5'er
2004 Dodge Ram 1500 QC 5.7 HEMI 4 X 4 Short Box Towing Package
Hide-A-Goose Gooseneck with 5" extension ball
RHR
Tecumseh, Kansas
Good Sam RV Club
Posted: 10/14/09 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I use these Levelers.
They are great. I purchased 2 boxes which is 4 levelers. They do not crack split or rust. If they get dirty you can wash them right off. Since they are angled you just either pull forward or back up until level then chock your tires.
Hitchhiker 2 LS RKTG 32.5
Chevy 3500 Duramax,Allison 2004 SRW
maxmorrow
Birmingham ala.
Posted: 10/14/09 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Something I did was to attach a piece of 1/4 inch plywood to the bottom board but about 9 inches longer. You will back up on the plywood and then the boards. This way they won't slide on asphalt or concrete. Has worked great for me.
If you ain't the lead dog...the scenery never changes!!!!
Rmcgrath53
Howell
Posted: 10/14/09 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I use my trusty laser level set and find what side is higher and then how much is the difference. Then I take a 3/4 board or 1 1/2 2x6 and place in back of tires and then drive up onto them, making sure the right thickness is under the low side With a level trailer at the wheels I then do the same for front landing gear. Done. I then raise and lower the landing gears until it is level with a torpedo level just inside the door Done
Ron
2009 sundance 2997bhs
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
a_flyfisher
PA and MT
Posted: 10/14/09 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I use hydraulic corner jacks. I don't know what they weigh. I just push a button or two and it's level.
a_flyfisher
Arcamper
Fayetteville, AR
Posted: 10/15/09 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Two sets of the plastic lego style blocks has been all we ever needed. I have seen people back in a campsite and start pulling lumber out of the camper and the truck. When done they have enough to build a small house and I never understand why it takes that much. I have never used any thing under the front jacks but I see people stack wood a foot tall and only let the jacks down a few inches, same on the rear. Then some have to have all the tires on wood even on a level site. Why? The best one was the guy that built a ramp for his sewer hose that must have had 40 feet of lumber used. To each his own I guess. The only wood I plan to haul will be for a campfire.
* This post was edited 10/15/09 08:39am by Arcamper *
2007 Keystone Laredo 29RL 5th
2008 Dodge 2500 Quad Cab SLT HD 4x4 6.7 Cummins with EB,6 speed auto
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
1994 Chevy 1500 5.7 extended cab PU
Pullrite 16k Superglide with Super Rail kit
Brakesmart & Prodigy P3
steelpony5555
Copperas Cove Texas
Good Sam RV Club
Posted: 10/15/09 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I used to haul a bunch of planks and blocks around till I got 2 sets of lego blocks (Lynx). It is not so much the weight but the room all that wood takes up. The blocks come in a nice little bag and don't take up much room at all. I also don't seem to pick up as much dirt (read mud) on the blocks as I did the planks. The planks did make nice fire started though. Block or wood is sort of like using a piece of rug or the RV mats under your awning. Both work but one just make life a whole lot easier.
03 Alpenlite Valhalla
07 Dodge 2500 Lone Star Edition 5.9 diesel
07 Honda Goldwing Burnt orange of course! (My new Baby)
06 Chrysler 300 Touring
Margarita machine---nothing better then sittin in the shade on a hot day sippin a Margie!
Delaine and Lindy
Linden Tn. (The View) /Gulf Shores, Ala.
Posted: 10/15/09 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Brian first of all I would like to Thank you for your service to our Country. We have always use the Lynx block type plastic blocks. They can be bought at Wally World for under $30.00 or so. Very light weight and easy to use. Don't know what type RVing you like but I would recomend two sets. I still carry the Lynx levelers even though our 5th wheel has 6 Hydraulic jacks and we have the side to side leveling system. But I have been in a few of the older parks were the sites weren't level and the Hydraulic Jack wouldn't extend enough to get the 5er level so I would have to raise the tires off the ground as for as I could then I put the Lynx blocks under the tire and then lower the 5er down on the blocks and put blocks under the Hydraulic Jacks a raise the 5er until level. Again I wouldn't use wood just having to handle them is enough problem. GBY...
2006 FreightLiner M2
Trailer Saver Air Ride (TSLB2H)
Pressure Pro System
2008 Chevy Silverado 1500 C/C (Grocery hauler)
2009 Chevy HHR LT 2
2010 Mobile Suites 38 RSSB 3/4
www.webspawner.com/users/lnhdch
We are BLESSED!!!!
