RV.Net Open Roads Forum: For those of you who have an 'RV' outlet at home
 > For those of you who have an 'RV' outlet at home
Page of 5
General RVing Issues Related Tips
BoatCop
Parker, AZ
Good Sam RV Club
Posted: 10/15/09 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
RV spot is next to the house, right where the main electrical service is. I snapped in a 30 amp breaker, ran wire and conduit 3 feet down from the box to a 30 amp weather-proof covered 30 amp plug.
With an adapter, it's a great place to plug in all the house Christmas lights.
Alan
BoatCop
1999 Southwind 34L
2009 Chevy Tahoe
2001 Jeep Wrangler TJ (TOAD)
Dutch_12078
Great Sacandaga Lake, NY
Posted: 10/15/09 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
20 amp GFCI outside outlet on the house. Runs everything I need to run when parked at home, including the AC.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
Tom N
Sarver, PA/Crystal River, FL/Indiana, PA
Posted: 10/15/09 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
I use 20 amp from a garage outlet. Use a 50' light extension cord to the motorhome. All I need is enough power to run the refrigerator and converter (to keep the batteries charged). Both satellite receivers are also always plugged in. We don't use the motorhome when parked at home so no high amperage drawing AC or hot water is needed.
-Tom
Sarver, PA/Crystal River, FL/Indiana, PA · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2003 Honda Civic EX · 2008 Honda Odyssey EX-L
tomlang
Los Angeles area
Good Sam RV Club
Posted: 10/15/09 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 75' generator extension cord that was rated for 20 Amps, but I changed the ends to a 15A plug on one end and a 30A receptacle on the other end. This is plugged into a 20A GCFI duplex receptacle on the side of the house (rated for 15A per side). I will soon be swapping out the receptacle and plug for 20A twist-locks. Then the entire circuit will be good for 20A, end to end. If the batteries are fully charged so the charger doesn't draw much current or if I set the charger to draw 10A or less, I can run one AC.
By the way, when I first set up at this location, all I had was a 100' light duty extension cord. If the charger needed too much juice, the voltage would drop below 105 volts and the EMS would disconnect. When I first upgraded to the heavier gauge cord and ends, the voltage drop was OK, but the charger load tended to trip the main breaker or GFI breaker. This is when I started dialing down the charge current.
Tom and Lynne
Tom is an Electronics Engineer, Lynne a retired teacher.
2003 Foretravel 38' U295
Yaj
The Milky Way Galaxy (Hartford, WI)
We have a RV 50 amp on the side of the house, in and down to main panel, dual 50 breaker. "Not" ground fault.
* This post was edited 10/17/09 12:45pm by an administrator/moderator *
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
2 dogs, 2 cats.
I wasn't thinking this far ahead!
Ron & Shirley
Lake of the Ozarks Missouri / Donna Texas Winter
Good Sam RV Club
Posted: 10/15/09 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Crazy Ray wrote:
30 amp wired to main panel. did the job myself.use the site. www.myrv.us/eletric . GREAT SITE JMO
cannot find this website??
Ron & Shirley
2005 Itasca 37B Suncruiser W24 Workhorse Chassis
To Discover New Oceans We Must Lose Sight Of The Shore
http://shirleysadventure.blogspot.com/
D & M
Laurel, MD
Good Sam RV Club
Posted: 10/15/09 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Likewise
Dave
Mary, the world's best wife (1951-2009)
Isabel & Buddy (the Bostons)
2005 Itasca Suncruiser 35A
Don't wait until its too late.
LAdams
Northern Illinois
Good Sam RV Club
Posted: 10/15/09 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
30 amp I installed myself in weatherproof box fed from outside (garage) breaker panel - no GFI...
Les
* This post was edited 10/16/09 07:23pm by LAdams *
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
smkettner
Good Sam RV Club
Posted: 10/15/09 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.myrv.us/electric/
electric needs to be spell checked
My city requires a NEMA 10-50R in the garage to eventually charge all of our electric vehicles. It was wired on a 40 amp breaker and #8 wire. As luck would be, there was a ground wire pulled but not connected so a NEMA14-50R popped right in for regular 50 amp service(limited to 40 amps). No problem as my RV is 30a so the dog bone gets used at home when needed.
debaets
California
Good Sam RV Club
Posted: 10/15/09 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Try, www.myrv.us/electric/
Steve & Jeri De Baets
Manhattan Beach, CA.
2004 Dolphin 5342
79 VW Convertible, Triple Black
Page of 5
