mr. ed
Madison, SD (but usually elsewhere)
Hello, friends. I've posted this question on the NuWa forum but decided to post it here also since it may benefit others. I've tried removing my porch light lens cover in order to replace the bulb but it refuses to budge. I've grabbed it every which way and even tried a large flat-bladed screwdriver at the bottom. I've squeezed the lens to the point where I'm afraid I'll break it. I didn't have difficulty with the covers inside my unit but this one is extra hard. Any ideas? Thanks...
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Moved from 5th wheels to Gen'l RVing Issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
jetboater454
FL
Same kind I have.Wanted to change out to a blue bulb,but as of yet,still white.But soon someone will say how they come off.
"If momma not happy ....Who cares.I have my TH AND my toys .
LarryJM
NoVa
mr. ed wrote: Hello, friends. I've posted this question on the NuWa forum but decided to post it here also since it may benefit others. I've tried removing my porch light lens cover in order to replace the bulb but it refuses to budge. I've grabbed it every which way and even tried a large flat-bladed screwdriver at the bottom. I've squeezed the lens to the point where I'm afraid I'll break it. I didn't have difficulty with the covers inside my unit but this one is extra hard. Any ideas? Thanks...
If you look closely there are some tabs on the left and right bottom of the lens close to each side that fit into the fixture so you need to push up on the cover from the bottom at those points and the cover will pop out.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
peteandpatty01
East Greenbush, NY
Good Sam RV Club
Just like mine. I have a 2002 four winds motorhome and the porch lite needed to be changed. I tryed everthing and finally took the motorhome to Albany RV. There the tech used a wide (about 3/4 inch) blade and worked the lens from the bottom, it did popped off but I sure thought it would break. Turned out he did not have a bulb so he reinstall the lens. By the way no charge. I got a new bulb and took the lens off as he did, it sure feels like it going to break. Changed the bulb and had just as hard a time putting the lens back. Needs some force to get it back in place. The bad news I did break the lens going back in, the good news mediun visosity cyananoacralate glue (crazy glue) repaired it good as new. I reinstaled the lens and all is well.
Poor design for a light lens is an understatment.
StoneyPgh
New Kensington, PA Steeler Country
Mine has two tabs on top and one in the center on the bottom. I squeezed the bottom of the lens in the middle and lifted it out, bottom first.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Prodigy Controller
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
PenMan
New Mexico
Good Sam RV Club
If you look closely at the photo above, you can see the two tabs on the bottom. Press up on that area carefully.
Chris and Jane and two boys who use a tent
2007 Rockwood Roo 23B
2006 Dodge Ram 3500, 4x4, Crew Cab, 5.9 diesel
1996 Harley Davidson Electraglide
old guy
Oregon (pronounced Or e gun)
you sure will break the lens if you use a screw driver. it works best to just squeeze the lenses with your hand and pull it out of the holder.
fisher60
Plant City, Florida
Good Sam RV Club
I had just the opposite issue with my porch light. Couldn't keep the lens in. Lost serveral. Wound up replacing the fixture. In my spare time it took abut a week. You wouldn't believe where the wiring was at!
'01 Dutchman Express 28A, Master Tow, '06 Tuscon, '05 Honda VTX 1300
Good Sam Life Member
mr. ed
Thanks for the replies, friends. I kinda figured the way to do it was to press in at the bottom (where the tabs are) but it seemed so difficult to do, as some of you also noted. I thought the thing would break first. I won't try the screwdriver method any more, either. Guess I was just frustrated and willing to try anything. At least the porch light isn't too important for me so it's not a priority. Still want to get it done, though....
