PandK
Greenville, SC
Good Sam RV Club
I decided to install a Progressive EMS after reading on RV.net about fried electrical systems. Yesterday while at our favorite COE park the EMS shut down the electric. Checking the EMS remote meter showed the two legs with 165 and 75 volts. Was hard to believe since we had been plugged in for two days with no problems. I got my meter to check out the park’s box and found 40 volts between the ground and neutral (should have read zero). Reported problem to park maintenance and moved to another site (tested the box before plugging in). Maintenance looked at the electrical distribution and put a notice on it saying “correcting bond between neutral and ground” meaning there truly was an electrical issue and the EMS saved our electrical system. We also heard that two others in the same camping loop had problems - one lost their converter and the other lost electric to their refrigerator. I am now definitely a believer in having an EMS and figure it just paid for itself.
Paul and Karla
Cinnamon & Pequeno - our Chihauhuas
2004 Rexhall Rexair DP3955
2006 Scion tC
Dynasty40
Northern California
Outstanding save! That's what I call a "defining moment". ...Dennis
Dennis and Debi
Monaco Dynasty Baron 40PFD
Towing a Chevy HHR W/
ReadyBrute
AZPops
Southwest
Great story, thanks for sharing. This is why my EMS is always between the power source and the Eagle.
Pops
edited 10/20/09 01:46am by AZPops *
Captain: Pops
Ist Mate: Harlee "Vicious Attack Dog" only if you try to move her when she's sleeping...
Trouble Maker: CALVIN
arctodus
Kansas
What is an EMS?
2001 F350 single wheel
7.3 Power stroke diesel
6 Speed manual tramission
Club cab
2000 Sprinter 300 by Keystone
30 ft
16 in 10 ply uniroal tires
Heavy duty axle
riggarob
Farmington, NH
You're right Dennis. I installed one the minute I bot the new pusher. After reading the stories on this site, I decided it was the only way to go. One thing though. If I use my 2 Honda 2000i's in parallel, I have to shut the surge protector off, it doesn't recognise 30 amps. No problem though, 'cause I know MY 30 amp supply is sound. Robbie
Dynasty40 wrote: Outstanding save! That's what I call a "defining moment". ...Dennis
edited 10/19/09 09:51pm by riggarob *
08 Fleetwood Providence 40X
FL-XC
US Gear Braking system
Blue OX towing system
06 Saturn Vue AWD toad
Wife and best friend Martha Baby
SweetPea - 16 year old "Maine coon cat" still mean as ever
Beware of those who point their finger the LOUDEST !
PandK
Greenville, SC
Good Sam RV Club
Here's what we have and a description of what the Electric Management System (EMS) does. It is installed between the outside source of electric and the AC distribution panel in you unit. It protects your unit from excessively high or low voltage problems.
Progressive EMS
SunflyerA
Andover, Minnesota USA
Good Sam RV Club
arctodus wrote: What is an EMS?
Energy management system....refered to on this thread could also be known as a surge guard.
EMS also refers to an in house system of managing your electrical system so you don't continue to trip breakers from over loading them.
sunflyer
2005 Fleetwood Excursion 39S
350 Cat
If you are what you eat; then I am fast, cheap and easy
Golden_HVAC
Fulltime, CA, USA
Hi,
This should be a rare problem, but as you see, it can happen. My guess is the ground wire broke at the main transformer, or electric meter to this loop of the campground.
The heating element can go bad when exposed to 160 volts. It can cause 40% more amperage to go through the heater, so it might use 5 amps instead of 3, and instead of 360 watts at 3 amps and 120 volts, it might be 800 watts at 160 volts and 5 amps. Lets hope that the refrigerator shut off before the ammonia line gets to hot and cracks, possibly leaking out flammable and stinky ammonia mixture.
Good Luck,
Fred.
Retiredblade
Western, Pa
These work also: www.campingworld.com/shopping/product/hard-wired-surge-guard/2480 last winter the same this happened at our camp ground and my neighbor had one and he came over to me and said "shut your electric off!" I did. The power surged way over what is safe. They called Florida power and they had been working on the lines and set the transformer to high. They came out right away and reset it. They are worth having.
Sam USCG
UltraKen
Ohio
riggarob wrote: You're right Dennis. I installed one the minute I bot the new pusher. After reading the stories on this site, I decided it was the only way to go. One thing though. If I use my 2 Honda 2000i's in parallel, I have to shut the surge protector off, it doesn't recognise 30 amps. No problem though, 'cause I know MY 30 amp supply is sound. Robbie
This has been discussed elsewhere. The problem is that the EMS doesn't see a ground on the portable generator.
UltraKen
Ex -1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Cat 300 - Model 3530
http://travel.webshots.com/photo/2396883070036776819PnWVFp
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
