Fliposo
Colorado
I need to put a 4 pin trailer connection on my '95 Jeep Wrangler. I'm having trouble identifying the correct wires to splice into. I have a shop manual, but the wire colors don't match the schematic. I have a Multi Meter, but unsure how to check. Can I pierce the ground wire, then check for current for turn, tail, and brake wires? Which setting on meter should I use? Thanks
Retired April '09
100+ days on the road so far
'08 Dodge 1500 Quad with Hemi
'09 Jayco Jayflight G2 23FB
Lobo2
Georgia
Easiest way is to get one of the Hopkins Easy Connectors. They are vehicle specific and they make one for Wranglers. It plugs into your existing wiring harness and requires no spicing. Good luck, Lobo
Fliposo
Colorado
Where is the connector on the harness? I found the bundle of 7 wires that run to the rear, then drop into the fender area.
Lobo2
Georgia
I think the factory wiring harness on the Wrangler has flat connectors so somewhere under the back end you should see them but they may be taped up with the wiring and hard to see. To be sure, Google "Hopkins Trailer Wiring" and on their site. You can see the harness for your vehicle and it should show installation instructions. Also, WalMart and most any of the auto parts stores carry a selection of the these adapters but usually just the most common. Hope this helps.
Rockiesview
Western Colo.
If the Wrangler has a connector recepticle already installed, there are adapters (7to4, etc) available at automotive stores.
Fliposo
Colorado
Lobo2 wrote: I think the factory wiring harness on the Wrangler has flat connectors so somewhere under the back end you should see them but they may be taped up with the wiring and hard to see. To be sure, Google "Hopkins Trailer Wiring" and on their site. You can see the harness for your vehicle and it should show installation instructions. Also, WalMart and most any of the auto parts stores carry a selection of the these adapters but usually just the most common. Hope this helps.
Thanks.
I Google'd them, and they list an application. But, no installation link. I wonder if connection is in behind left tailight? That is where the wiring for right side splits off. I live 30 miles from any big auto stores, so I'm limited to access.
Larry202br
Olathe, Ks
Good Sam RV Club
You can connect one lead of your DMM to a good ground, then probe the harness at the left tailight with the running lights on. Use a small straight pin to pierce the insulation. When you find hot, that's the running lights. Then do the same with the left and right turn signals.
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
Krusty
Calgary, Alberta,Canada
Try to probe for power at a connector or light socket etc. If you pierce insulation it will lead to corrosion and troubles in the future.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Jerry01
Valencia, Ca.
Not sure if you already have a 7 pin round connector or not. As others have said, the best way is to get an adaptor from 7-4. If you do not have the 7 pin connector, then try this http://www.etrailer.com/pc-VWH~118356.htm. I used this for my buddies truck. Works awesome, and there is no splicing involved. Jerry.
2005 GMC Sierra 2500HD SLT CC/SB D/A 2wd
EFI Live, Line-x, XM radio, Bilstein 5100's, MBRP cat back, BFG 285/70/17 A/T
2002 Keystone Sprinter 26ft.
Prodigy controller.
Honda 2000 gen.
Xantrex XADC 60a.
Lobo2
Georgia
Fliposo wrote: Lobo2 wrote: I think the factory wiring harness on the Wrangler has flat connectors so somewhere under the back end you should see them but they may be taped up with the wiring and hard to see. To be sure, Google "Hopkins Trailer Wiring" and on their site. You can see the harness for your vehicle and it should show installation instructions. Also, WalMart and most any of the auto parts stores carry a selection of the these adapters but usually just the most common. Hope this helps.
Thanks.
The web site shows a picture of the harness for the Wrangler and the male and female flat connectors pictured are the same as what's on yours. They're under the rear somewhere, maybe stuffed behind something. Lobo
