I was planning on using a my honda Eu3000 at around 10,000 feet. I was wondering what I should expect for performance. I have used it at 7000 feet at it seemed to work well still running the AC I was just curious what another 3K would do. Thanks for any info.
Dave i got one 3000i and took it to 7000ft and it would not run my a/c so i got a second one and all is well now. i have all the power i need no matter how high i go..
Becky tim
tabby and max
twin honda 3000is
prowler 25 rls extream edit.
2006 titan 4x4
You should expect a reduction in power just like with any normally aspirated engine. I've never seen HOT weather at 10,000 feet so you won't be needing all that power anyway. Good luck / skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles) Rockwood 8314SS 34' travel trailer
Dave the honda will lose 3%-5% power per 1000ft of elavation. thats quite a bit of loss, now skip i camp at 9000ft alot and have 90 deg. temps in july and aug. quite a bit and to me, im on vacation i dont want to be uncomforable for my naps.(no windows in bedroom,)
Well on my YAMAHA 2400, I rejet anything over 7,000 ft, runs like a dream. JMO
RET ARMY , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, 4 SAMS 6VOLTS, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler/Honda CR V. Garmin GPS 7200 . "Living Our Dream". NASCAR FAN (14,18,,20,11) Love CO & NM
I doubt a 3000 watt generator would run an AC at 10,000 ft.
Question is, where on earth are you going that it gets hot enough to run an A/C at 10,000 ft.
I camped at 11,000 ft with my previous travel trailer in the middle of August and the temperature would not make it much over 60 in the day, and the nights were right about freezing.
2000 National RV Tropi-Cal 37 ft Double Slide Ford V-10
1994 Toyota Celica on a Master Tow Dolly (40 MPG)
I should have made myself clearer. This is for winter use during the skiing season. This would only be for light loads no ac mostly just running lights charging batteries and ocassional Microwave use. I was just wondering if the thing would run at all. I expect it would but just curious about those that have ran theirs at 10k.
Does it have an altitude adjustment like my ONAN has?
Bobbo, Linda and the furry kids (German Shepherd and German Shepherd mix)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
dave17352 wrote: I was planning on using a my honda Eu3000 at around 10,000 feet. I was wondering what I should expect for performance.
Dave
I re-jet my Honda EU2000i for altitude (most of the time I'm camped in a ski area or sno-park at 8,000 ft) not so much for more power, which it will have, but mainly to avoid running overly rich and the more frequent maintenance issues it causes (fouled plug, blocked spark arrestor screen and more rapid carbon build up in the cylinder head.
