RV.Net Open Roads Forum: 2 questions need help with please-Ref and Onan
 > 2 questions need help with please-Ref and Onan
Tech Issues Related Tips
dad4papa2
Missouri
Posted: 10/26/09 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Plugged into shore power and couldn't get anything. 12 volt batteries tested at 13.5 volts. we also unplugged the refrig and plugged into house power still nothing. We did check the 2 wires coming in from battery to refrig and 12 volts were present.
I'm feeling like a control box.
Still wondering how hard starter is to replace????
Thanks much Dad
TEXAS
Centerville Tx
Posted: 10/26/09 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
If you have what I think you do. Starter is easy to change. Getting to it may be another story.
dad4papa2
Missouri
Posted: 10/26/09 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
it appears that about 4 bolts hold it in. Not sure but I have a transmission stand might lift it right out of there.
Dad
Generator Jim
Conway, SC
Good Sam RV Club
Posted: 10/26/09 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
What is the full model number of the generator?? There are three models of 6.5 ONAN generators.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
Chris Bryant
DeLand, Florida, USA
Posted: 10/27/09 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Look at the control box on the refrigerator, it will have 2 blue wires coming out going up in to the box- they will have quick connects on them. Unhook them and hook them together (they run all the power up to the on/off/high humidity switch, which goes bad quite often).
-- Chris Bryant
My RV Service Blog
The RV.net Blog
dad4papa2
Missouri
Posted: 10/27/09 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Chris are you saying to connect the two wires to each other after you disconnect them from the box??? Will this let the unit work then? Or will this just put power to the light letting you know the box is control box is not working??
Thanks Dad
Jim I will have to get that info if he pursues this MH.
Thanks Dad
Chris Bryant
Posted: 10/27/09 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Yes- hook the wires coming out of the board together (they are made to do that), which should make it work again- the only caveat is the interior light will not work, but then you will know what's wrong, and can replace the high humidity switch.
The board actually comes with those wires hooked together for single door models (without a light and door heater).
lfeather
Titusville, FL
Posted: 10/27/09 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Deleted. OBE
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Toad
SMI Air Force One toad brake
dad4papa2
Missouri
Posted: 10/27/09 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
wow here's the deal-the owner of the MH got the Gen started and it is running fine. Come to find out the Batterys were just low enough that it wouldn't crank.
Refridg has te high humidity switch inside the door which we didn't see and it was in off position. Turned switch on and it lit find.
Problems are cured. Will Probably need new Batteries.
Thanks for all the help and tips.
Dad
